Re: 1969 Barracuda M code
[Re: Wedgeman]
#2139284
08/23/16 01:42 PM
08/23/16 01:42 PM
Posts: 8,346 fredericksburg,va
cudaman1969
fredericksburg,va
Got a question, this is going to be on the original engines. When installing the 440 in our cars, did the factory use the vapor canister over the fuel pump like used in the GTX and RT 440-Hemi? If used, then there would be two lines running to the tank, 3/8 & 1/4. Mine only has one 3/8, is this correct? I guess I'm asking, where those canisters omitted on these cars with just the line between carb and pump?
[Re: Wedgeman]
#2139699
08/24/16 01:26 AM
08/24/16 01:26 AM
Posts: 1,554 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
I'd like to get an M Code notch. I have some interesting trades.
Cheers
1969 Hemi Charger R/T, 1970 Charger 472 Hemi 6 Sp 1969 Charger Pro Tour Project 1971 Barracuda Convert 1970 440 6pack Superbird, 1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue) 1967 Barracuda Convert 1968 Barracuda Coupe 1972 Charger Rallye wanna be RT 1972 Sebring Plus 440-6 Clone 1969 Coronet Pro Street 2009 Challengeer SRT8 stick 1992-1986 Body 2500 4x4 440 stick 1982 Ramcharger 318 Sniper- getting enhanced. 1991.5 W250 Cummins- Big Chief
[Re: cudaman1969]
#2139718
08/24/16 01:47 AM
08/24/16 01:47 AM
Posts: 43,621 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Got a question, this is going to be on the original engines. When installing the 440 in our cars, did the factory use the vapor canister over the fuel pump like used in the GTX and RT 440-Hemi? If used, then there would be two lines running to the tank, 3/8 & 1/4. Mine only has one 3/8, is this correct? I guess I'm asking, where those canisters omitted on these cars with just the line between carb and pump? No canisters, one single 3/8" line. ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2139744
08/24/16 04:28 AM
08/24/16 04:28 AM
cudaman1969
fredericksburg,va
Got a question, this is going to be on the original engines. When installing the 440 in our cars, did the factory use the vapor canister over the fuel pump like used in the GTX and RT 440-Hemi? If used, then there would be two lines running to the tank, 3/8 & 1/4. Mine only has one 3/8, is this correct? I guess I'm asking, where those canisters omitted on these cars with just the line between carb and pump? No canisters, one single 3/8" line. Thanks, what I thought too. had a small controversy on another post about this. Wanted to make sure.
[Re: Wedgeman]
#2140273
08/24/16 11:05 PM
08/24/16 11:05 PM
Posts: 737 Michigan
BlueRacer69
Was the line 3/8" all the way from the gas tank to the carb? If so, what about the gas tank sending unit? I was under the impression all the A-body 1969 sending units were 5/16" outlets no matter the engine size. If so, how were the two mated up?
[Re: cudaman1969]
#2141451
08/26/16 07:35 PM
08/26/16 07:35 PM
Posts: 16,162 Mesa, Arizona
dart4forte
Mesa, Arizona
I'm sure all big block Darts and Cudas were 5/16 lines
Abe Lincoln
[Re: dart4forte]
#2141539
08/26/16 10:44 PM
08/26/16 10:44 PM
Posts: 737 Michigan
BlueRacer69
I'm sure all big block Darts and Cudas were 5/16 lines I thought so too, same as the 383 Darts, but it sounds like Rhino is saying something different.
[Re: BlueRacer69]
#2141567
08/26/16 11:22 PM
08/26/16 11:22 PM
Rhinodart
Rhinotruck
Rhinotruck
Rhino had a brain fart... ![fart fart](/ubbthreads/images/graemlins/custom/fart.gif) I meant to say 5/16" line but I typed 3/8", old age and senility sucks. ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif) I will be looking at a couple of factory M-Code Darts and one Barracuda next week, I will make sure both sides of my brain concur once again... ![panic panic](/ubbthreads/images/graemlins/custom/panic.gif)
A-Body's RULE!
[Re: Rhinodart]
#2141576
08/26/16 11:34 PM
08/26/16 11:34 PM
Posts: 737 Michigan
BlueRacer69
Rhino had a brain fart... ![fart fart](/ubbthreads/images/graemlins/custom/fart.gif) I meant to say 5/16" line but I typed 3/8", old age and senility sucks. ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif) I will be looking at a couple of factory M-Code Darts and one Barracuda next week, I will make sure both sides of my brain concur once again... Rhino. Post back next week on what you find out. Maybe a few pics would even be nice too. I understand your old age completely lol.
[Re: Rhinodart]
#2141613
08/27/16 12:26 AM
08/27/16 12:26 AM
dart4forte
Mesa, Arizona
Rhino had a brain fart... ![fart fart](/ubbthreads/images/graemlins/custom/fart.gif) I meant to say 5/16" line but I typed 3/8", old age and senility sucks. ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif) I will be looking at a couple of factory M-Code Darts and one Barracuda next week, I will make sure both sides of my brain concur once again... Maybe the M code had 3/8?
Abe Lincoln
[Re: BlueRacer69]
#2141617
08/27/16 12:28 AM
08/27/16 12:28 AM
dart4forte
Mesa, Arizona
I'm sure all big block Darts and Cudas were 5/16 lines I thought so too, same as the 383 Darts, but it sounds like Rhino is saying something different. Well I know the 383 cars were 5/16. My GTS had 5/16 when I tore it apart. Since it's not a racecar I stayed with 5/16 Not to change the subject but what happened to that B5 blue M code Dart that was on Moparts for sale?
Abe Lincoln
[Re: dart4forte]
#2141685
08/27/16 01:40 AM
08/27/16 01:40 AM
Posts: 140 Ohio
carteravs
Ohio
Rhino had a brain fart... ![fart fart](/ubbthreads/images/graemlins/custom/fart.gif) I meant to say 5/16" line but I typed 3/8", old age and senility sucks. ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif) I will be looking at a couple of factory M-Code Darts and one Barracuda next week, I will make sure both sides of my brain concur once again... Maybe the M code had 3/8? Not mine, it's 5/16"
[Re: 440PURSUIT]
#2149365
09/07/16 02:12 AM
09/07/16 02:12 AM
Posts: 1,187 USA
big-block-dave
USA
Cheers I'd probably sell mine.....no trades
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
[Re: big-block-dave]
#2168150
10/05/16 01:12 AM
10/05/16 01:12 AM
Posts: 1,187 USA
big-block-dave
USA
[Re: Wedgeman]
#2249480
02/08/17 01:36 AM
02/08/17 01:36 AM
cudaman1969
fredericksburg,va
Need to get this post back up front. Now, anything going on? How's the builds coming along? Question for the Cuda cars, driveshafts, if sure it's original, is it tapered on both ends? I know the Darts are, I have two. I need one if someone has a lead on one, all the same whether 340 383 or 440. Mike
