Re: Camshaft duration
[Re: hot67cuda]
#214078
02/04/09 03:19 PM
02/04/09 03:19 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
A big cam will work in a bigger motor with more squeeze a lot easier. The bigger motor absorbs more of the duration and is able to use it. There is such a thing as to big of a cam for a certain motor. If the motor is small it will need more compression with the bigger cam to work best.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Jacob Pitt]
#214079
02/04/09 07:48 PM
02/04/09 07:48 PM
Posts: 3,210 robin hood country
deaks
robin hood country
My car has slow 60ft times, which i think is down to the cam being too big, .280@50, 440 with 11-1 comp. Mike
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: WILD BILL]
#214081
02/04/09 08:33 PM
02/04/09 08:33 PM
deaks
robin hood country
On the time posted 1.66, which is usual, if i can keep it in one piece this year i think it will go 10's, with a smaller cam maybe mid 10's. Mike
[Re: hot67cuda]
#214084
02/05/09 02:28 AM
02/05/09 02:28 AM
Posts: 43,236 Bend,OR USA
Cab_Burge
Big motors like big cams, I'm sure the new motor will like the cam you have now a lot better than the old motor does. I tried a solid roller in my pump gas low conpression 518 C.I. that was 274@.050 on 106 LSA, the motor didn't like it on the dyno versus the old cam which was a dual pattern solid roller with 260@.050 intake and 266 @.050 0n the exhaust with 108 lsa I didn't run the bigger cam at the track or on the street, I took it out and put the old cam back in, chicken I guess I am putting the bigger cam in a higher compression motor now with better heads, more carburetion and less C.I.(464 C.I.)so it will be interesting to see the results. I will put the details on the motor as soon as I know when it will get dynoed and ask for comment and guesses on the results Lats thing is big motors like big camshafst, I would use the one you have now if it is availble, not in the old motor if the old motor is still together and usuable
