Missing at cruise speed
#2139624
08/23/16 11:24 PM
08/23/16 11:24 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Hey guys, this 547 engine has a strange slight miss at cruise speed, if you squeeze the pedal and load the engine slightly it clears, also belting it it's fine and just goes. Any idea's ? It cant be spark I'm guessing. CHEEEEEERS
1963 Plymouth Max Wedge 1971 Barracuda
Re: Missing at cruise speed
[Re: ozymaxwedge]
#2139633
08/23/16 11:42 PM
08/23/16 11:42 PM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
Al, may be a lean situation ? Do you have a AFR set up ?
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: ozymaxwedge]
#2139642
08/23/16 11:47 PM
08/23/16 11:47 PM
ozymaxwedge
Australia
No Tex I don't ant don't have time to dyno before Alice trip
[Re: ozymaxwedge]
#2139668
08/24/16 12:38 AM
08/24/16 12:38 AM
Posts: 43,263 Bend,OR USA
Cab_Burge
High vacume misfire, maybe it is a vacume leak Ignition would be the other one I would look at
[Re: ozymaxwedge]
#2139682
08/24/16 01:06 AM
08/24/16 01:06 AM
tex013
Sydney,Australia
Al, easiest thing is go up on the primary jets by 2 .Then road test . Are you running a powervalve on primary ? Like Cab said vacuum leak at high cruise vacuum - also show as lean
Tex
[Re: ozymaxwedge]
#2139822
08/24/16 11:41 AM
08/24/16 11:41 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I don't have much experience on 2 4150's on a TR, but you might not be on the primary circuit yet. Sounds lean. How is the transfer slot exposure? What IFR? Maybe Mr. Thump will chime in.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#2139877
08/24/16 01:09 PM
08/24/16 01:09 PM
Thumperdart
State of confusion
Before you can properly tune ANY engine be it carbs, efi, blowers etc, you need data and w/carbs it`s a wideband. So IF you had one you could tell us the rpm/throttle range and afr`s then w/that info we could better nail the answer(s). I had a 9 second car but ran 10`s until I chassis dynoed it and found out how far off I was on my tune. As I say; it`s bad enuff to be dinosauric running carbs apparently BUT w/out data it`s a guessing game especially on street cars w/a variable of throttle positions from idle, transition, cruise and wfo.............
[Re: Cab_Burge]
#2140100
08/24/16 07:13 PM
08/24/16 07:13 PM
Thumperdart
State of confusion
You migt want to try using some really thin wire(the thinnest you can get) to make up some upside down J to put in the idle bleeds, all eight That should inrichen the mixture all the way through the entire RPM range If that fixes the miss you know your on the edge of a lean misfire at part throttle operations. The next move is to get a set of the next smaller I.D. idle air bleeds, maybe.001 to .003 smaller to fix it Make sure there are no vacaume leaks also Great quick way to test for sure and at least give you a direction to go also the ifr`s and idle bleeds have a big impact. Can you post the specs on the carbs like idles, hi`s, ifr`s, emulsion etc...........
