Driveshaft Length? #213911
02/04/09 01:12 PM
02/04/09 01:12 PM
bmoparmofo Offline OP
Hi, I have a 69 charger with a 383/727 8 3/4 set up. Its missing the driveshaft.The book is calling for 52.07 length and 3" diameter I believe. I found someone with a shaft that is measuring 51 1/4 from the center of both u-joint holes.He thinks its 3 1/4 diameter.Do you guys think this will work or no? Will the yoke take up the 3/4 inch or so? Thanks for any help!
Re: Driveshaft Length? [Re: bmoparmofo] #213912
02/04/09 01:49 PM
02/04/09 01:49 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Won't work. It will cause the yoke to be too far out of the housing which leads to wobble and will wipe out the rear trans bushing and housing. For a correct fit the yoke will only be 3/4 to 1' away from bottomed out.
Re: Driveshaft Length? [Re: stumpy] #213913
02/04/09 05:27 PM
02/04/09 05:27 PM
Thanks for the reply. Thats what I was wondering about.Hard to believe 3/4 of an inch would make such a difference.It does make sense due to what force goes through it though.Thanks for the input again,I'll have to keep looking.
Re: Driveshaft Length? [Re: bmoparmofo] #213914
02/04/09 05:37 PM
02/04/09 05:37 PM
scratchnfotraction Offline
shove yoke all the way in till bottomed out
measure from center of u-joint cap to center of u-joint cap
subtract 1"
size round can be bigger or smaller around...just not too skinny
get one from a wagon/c-body or something and have it cut down and balanced
thats they way I build them swaping drive lines around
Re: Driveshaft Length? [Re: scratchnfotraction] #213915
02/05/09 11:23 AM
02/05/09 11:23 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
You can often fit a longer than factory length driveshaft in place. As long as it doesn't bottom out. 3/4" - 1" is all the yoke clearance needed.
Shorten than factory length is a definate recipe for vibration or worse tailshaft breakage.
