Page 7 of 11 1 2 5 6 7 8 9 10 11
Re: The Road to Drag Week, 2016 [Re: Bad340fish] #2138388
08/22/16 09:13 AM
08/22/16 09:13 AM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Originally Posted By Bad340fish
Billy I am glad to see you are already driving it around before drag week.
My dad and I got mine out today for a good 50ish mile jaunt in and around town today. It feels good, sounds good, and I am starting to get the hang of the EFI stuff so its manners are getting better and better.
I am still having a problem with the fuel getting hot. I am quite certain I heard the fuel boiling in the tank when I shut the car off today. I can't make any other sense of what the sound would be that lasted 30-45 seconds after I shut the car off. It looks like I will be working on a fuel cooler before drag week.
Efi correct could the noise your hearing just be the fuel return line draining back into the fuel tank....just a thought
Good luck
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: The Road to Drag Week, 2016 [Re: turbo toad] #2138427
08/22/16 11:07 AM
08/22/16 11:07 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Working on getting Joel's dual fuel system plumbed. The car will go down the road using pump gas in the stock tank, and a Holley Red pump, and can easily be switched over to race gas in the 3 gallon fuel cell.
69 GTX 68 Road Runner
Re: The Road to Drag Week, 2016 [Re: turbo toad] #2138470
08/22/16 12:02 PM
08/22/16 12:02 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Good luck
Thought about that, but the tank should be 2/3 or more full and my return is lower than that.
I went back and checked my mileage, we were out just under 3 hours and covered 75 miles which is the longest trip with the EFI so far. This is the first time I have heard that noise.
Jericho, that setup looks good!
68 Barracuda Formula S 340
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2138492
08/22/16 12:32 PM
08/22/16 12:32 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Got mine out to the track for the first time with the EFI. Ran decent considering the weather. Also tried the 30" tall tires with the 3.55's to see how it would fair. I really don't want to swap tires during the week, but the tall tires cost me 0.08 in the 60' alone.
Looks like I might try the MT ET Street SS tires, they appear to have a bit more tread than my current Hoosiers. Anyone try them yet?
Also logged quite a bit of street miles, rolled up to Woodward, and got caught in a few nasty rain storms.
Don't have much more to do. Long wheel studs just arrived on my porch, so I will take care of that tonight just in case any tech guys want to hassle me.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2138701
08/22/16 04:42 PM
08/22/16 04:42 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
Against my better judgement, I put my shortblock together before i had the heads ready. These heads have never been on this shortblock, and wouldn't you know, it has valve to piston issues. So I have to tear it apart and cut the pistons. Arg. I worked on that for a while, but got kind of frustrated and tired of it. so I opted for a change of pace and worked on the wiring. That should be easy to finish, then I'll get back on the motor.
At least my trunk monkey woke up long enuff to get something done while I was going backwards....
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2138717
08/22/16 05:03 PM
08/22/16 05:03 PM
Minnesota
Minnesota
I'm going to run PAC endurance valve springs with #255/635 pressure. It takes lots of oil to cool them on the long street drives, so I plumbed the block for full time oiling to the rocker gear. I am taking out my old Landy roller rockers, because they do not oil the tips well. New Stage V rockers from FHO that are drilled to oil the intake rollers are going in.
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2138999
08/22/16 11:22 PM
08/22/16 11:22 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Looks like Jeff may be taking that trunk monkey moniker a little too serious!!
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2140167
08/24/16 09:01 PM
08/24/16 09:01 PM
Minnesota
Minnesota
Why does the wiring always take so long? Even when I pare it down to the bare essentials, it is a challenge. The steering column had to come out just to make room to get at stuff. I'm too old to be working under the dash like this...
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2140179
08/24/16 09:13 PM
08/24/16 09:13 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
HAHAHA no way is all that from under that dash!
Mopar to the bone!!!
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2140196
08/24/16 09:46 PM
08/24/16 09:46 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
lol did you have a telephone switch installed behind the cluster? Is that 25 pair I spy?
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2140211
08/24/16 09:57 PM
08/24/16 09:57 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Does not look like fun
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2140231
08/24/16 10:26 PM
08/24/16 10:26 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
God I hope we don't have wiring issues on Drag Week...
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2140362
08/25/16 12:39 AM
08/25/16 12:39 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Hey that looks like my EFI install lol
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2140447
08/25/16 09:05 AM
08/25/16 09:05 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
https://www.youtube.com/watch?v=zysOEUd1YwQ
I have a feeling this is how my Drag Week is going to go...
Re: The Road to Drag Week, 2016 [Re: JERICOGTX] #2140523
08/25/16 12:03 PM
08/25/16 12:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just for info... the MSD tech support trailer
will NOT be going on DW this year... you can call
the tech line for help
wave
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2141074
08/26/16 01:06 AM
08/26/16 01:06 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Mike are you sneaking around on Facebook? haha that is where I saw that announcement.
I am hoping to hit the track tomorrow(friday) night if all goes well.
Re: The Road to Drag Week, 2016 [Re: Bad340fish] #2141214
08/26/16 11:22 AM
08/26/16 11:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
No.. the wife told me about it.. I dont do FB
wave
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2141217
08/26/16 11:28 AM
08/26/16 11:28 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Install the fuse panel in an easily accessible spot, like the glove box, and you won't have to stick your head under the dash.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2141232
08/26/16 11:59 AM
08/26/16 11:59 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Stealing those pictures. That is HILARIOUS.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: The Road to Drag Week, 2016 [Re: Hemi_Joel] #2141348
08/26/16 03:39 PM
08/26/16 03:39 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
While the MSD trailer won't be there, a Holley trailer WILL be and I expect an MSD tech will be on that trailer
