Factory AC switch for aftermarket AC in non AC car?? #2135593
08/18/16 01:20 AM
08/18/16 01:20 AM
NW Ohio
6pkaar Offline OP
6pkaar  Offline OP
NW Ohio
Can I use a factory AC / heat dash switch set up for adding aftermarket AC to a factory non AC car. I like the "factory" look. Or do I have to use whe switches the aftermarket unit has?
Re: Factory AC switch for aftermarket AC in non AC car?? [Re: 6pkaar] #2135793
08/18/16 12:46 PM
08/18/16 12:46 PM
NJ, USA
bill440rt Offline
bill440rt  Offline
NJ, USA
The Classic Auto Air setup for '68-'70 B-body uses the factory slider switches. You only have to replace the contact switch inside the unit with one of theirs that they provide. Factory look is retained.
Re: Factory AC switch for aftermarket AC in non AC car?? [Re: 6pkaar] #2135893
08/18/16 02:59 PM
08/18/16 02:59 PM
Unfortunately back in New York
N
Nukechargerboy Offline
N
What car are you going to put this in? I know on the 68-70 B bodies they have their own controller. It looks pretty good, if you're not too hung up on the factory look. If you have heater controls, they have an option for that too. I'd hunt around on their website and call the tech line.
I do have their system in my Charger. It's pretty good at keeping the car cooled off. It's by no means as efficient as the r-12, but it is ok.
Re: Factory AC switch for aftermarket AC in non AC car?? [Re: Nukechargerboy] #2136336
08/19/16 12:39 AM
08/19/16 12:39 AM
NW Ohio
6pkaar Offline OP
6pkaar  Offline OP
NW Ohio
Sorry, I should have had it in my original post. This is in a 1970 'Cuda ralley dash.
