Will this raise the brake pedal at all?
with everything spooned up high and tight it would allow less pedal travel to actuate the brakes but for a higher at rest pedal (which I think is what you are asking), it would take an adjustable pushrod (manual brakes) or custom fabbing a longer rod if power brakes to raise the pedal
