Page 6 of 6 1 2 3 4 5 6
Re: Tubing benders [Re: sgcuda] #2142021
08/27/16 05:52 PM
08/27/16 05:52 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
The die doesn't need the grease. The support block does because the tube slides through it while bending.
[image][/image]
Re: Tubing benders [Re: sgcuda] #2142032
08/27/16 06:11 PM
08/27/16 06:11 PM
Q
Quicktree Offline
Quicktree  Offline
Q
the grease on the die was to keep it from rusting. but I did put a little on the groove when bending. maybe that was wrong
Re: Tubing benders [Re: sgcuda] #2142033
08/27/16 06:16 PM
08/27/16 06:16 PM
sgcuda Offline OP
sgcuda  Offline OP
Can't be too wrong. You built a whole car that way. shruggy
Besides, the die doesn't do any pulling. The forward clamp pulls the tube around. The die is just there to maintain shape.
[image][/image]
Re: Tubing benders [Re: sgcuda] #2142037
08/27/16 06:30 PM
08/27/16 06:30 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I spray with WD-40 as its pulling .
Re: Tubing benders [Re: FastmOp] #2142060
08/27/16 07:00 PM
08/27/16 07:00 PM
Q
Quicktree Offline
Quicktree  Offline
Q
that should work, doesn't take much
Re: Tubing benders [Re: sgcuda] #2142063
08/27/16 07:08 PM
08/27/16 07:08 PM
sgcuda Offline OP
sgcuda  Offline OP
With the amount of force I found that it takes to pull C/M, I don't know if I would want to use something as thin as WD-40. And I did find that a little goes a long way.
[image][/image]
Re: Tubing benders [Re: sgcuda] #2142066
08/27/16 07:10 PM
08/27/16 07:10 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I was using air over hydraulic. It did fine with no galling. I just spray the pipe and start bending 😊
Re: Tubing benders [Re: Quicktree] #2142169
08/27/16 10:34 PM
08/27/16 10:34 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted By Quicktree
Originally Posted By MR_P_BODY
I just used cheap wheel bearing grease with a
brush
wave
that's what I used, that is whats on the die, just been setting up for a while.
I hope you mean lube just the pins, instructions on my JD 32 said to never use lubricants on the forming dies groove, the tube will tend to slip backwards if used.
don't know nothing about the JD 32, I watched a friend who has bending tube for a long time he used grease on the die. mine never slipped.
Who knows, but I'll follow my instructions., besides, grease attracts dirt and grit which will scratch the tube and die then stress risers form, then all the extra work getting that mess off of everything, affecting the weld, no thanks, I'll do without it.
Re: Tubing benders [Re: cudaman1969] #2142177
08/27/16 10:51 PM
08/27/16 10:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I did it for 34 years.. grease... wipe most off
with paper towel... if you feel anything I checked
with my fingers
wave
Re: Tubing benders [Re: sgcuda] #2142271
08/28/16 02:30 AM
08/28/16 02:30 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
No grease here. I do wipe the tube down to remove any dirt, grit, etc. And I pay attention to the dies and polish them as needed. Dirt, metal grit will scratch and damage the die and the tube.
Re: Tubing benders [Re: sgcuda] #2142428
08/28/16 01:27 PM
08/28/16 01:27 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I have never used any lube on a bender either
