how to straighten steel 3/8 fuel line coil #212684
02/03/09 09:39 AM
02/03/09 09:39 AM
ERIE PA home of the RENCH MOB
mike_vango Offline OP
i have a 25 ft coil of steel fuel line. how is the best way to straighten it (without special tools) before i bend it up to fit the car. i will be running it from the tank to the pump. thanks
Re: how to straighten steel 3/8 fuel line coil [Re: mike_vango] #212685
02/03/09 10:00 AM
02/03/09 10:00 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
I have seen rolls of soft copper straighted by stretching. Unroll,clamp to tree or something unmoveable and pull with a come a long or vechicle. Will work on soft copper,don't know about steel.
Re: how to straighten steel 3/8 fuel line coil [Re: mike_vango] #212686
02/03/09 10:03 AM
02/03/09 10:03 AM
Cleveland Ohio
Discoquik Offline
Discoquik  Offline
Cleveland Ohio
Roll it out flat against the floor. It can be very straight after doing so. I use a 2x6 board to keep it from having any "bumps" from any cracks in the concrete. Basically roll it out like a carpet with light pressure forcing down on the roll while someone holds the other end. Very easy!
Re: how to straighten steel 3/8 fuel line coil [Re: Discoquik] #212687
02/03/09 10:07 AM
02/03/09 10:07 AM
Roll it out flat against the floor. It can be very straight after doing so. I use a 2x6 board to keep it from having any "bumps" from any cracks in the comcrete. Basically roll it out like a carpet with light pressure forcing down on the roll. Very easy!
roll it out like a carpet! thats my specialty. i'm just so afraid of kinking it.
Re: how to straighten steel 3/8 fuel line coil [Re: pushbutton] #212688
02/03/09 10:21 AM
02/03/09 10:21 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That's gonna change the diameter of the tubing, very bad idea and advise.
Roll it out on the floor and you will be fine.
I have bought and installed 100s of rolls of copper tubing in my time, as I'm in the propane business.
Re: how to straighten steel 3/8 fuel line coil [Re: Challenger 1] #212689
02/03/09 12:26 PM
02/03/09 12:26 PM
roll out on the floor and if possible use a corner to keep it straight. Do NOT move bend or stretch any more than you absolutely must because you will work harden the piece. I used to work in refrigeration, one day I wasplaying with a scrap ofcopper tube. Two or three bends back and forth was all it took--couldn't really bend it after. If you do so, you will then have to use heat to anneal it. if it is "tinned" this can be very tricky
Re: how to straighten steel 3/8 fuel line coil [Re: Challenger 1] #212690
02/03/09 01:04 PM
02/03/09 01:04 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
you don't have to pull copper hard enough to change the size. I said i didn't know about steel. You will have to use tubing benders after. I've unrolled a few rolls of soft copper in my time,never saw any come out straight enough that I would want to use on a car of mine.
Re: how to straighten steel 3/8 fuel line coil [Re: pushbutton] #212691
02/03/09 01:57 PM
02/03/09 01:57 PM
Cincinnati, Ohio
Cincinnati, Ohio
The OP was asking about steel tubing, I don't know how we got onto copper.
I would never use copper anywhere on any of my cars, same with aluminum tubing. It don't belong on a street car.
Re: how to straighten steel 3/8 fuel line coil [Re: Challenger 1] #212692
02/03/09 06:58 PM
02/03/09 06:58 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
I agree i wouldn' use copper either,Iwas just telling him the stretching process might work on steel tubing,but didn't know that it would.I realized he wasn't going to use copper on his car. Sorry if I confused anybody.
Re: how to straighten steel 3/8 fuel line coil [Re: pushbutton] #212693
02/03/09 08:37 PM
02/03/09 08:37 PM
It matters not whether you're speaking of copper, steel, or what. You work it the same way. You do NOT stretch it.
Re: how to straighten steel 3/8 fuel line coil [Re: mike_vango] #212694
02/04/09 10:36 AM
02/04/09 10:36 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Mine too.......
Set up a "dead man" get out your Crain pole stretcher and use the tubing stretcher attachment. Stretch until you get a slight bow in the poles..........
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: how to straighten steel 3/8 fuel line coil [Re: Challenger 1] #212695
02/04/09 12:34 PM
02/04/09 12:34 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Why do you say that? What's wrong with aluminum tubing, it's a lot easier to work with...
Re: how to straighten steel 3/8 fuel line coil [Re: DaytonaTurbo] #212696
02/05/09 07:59 AM
02/05/09 07:59 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Im my limited experience (aluminium and copper/nickel) you won't get a straight length by unrolling it flat - there is always a bit of 'memory' that will give you a slight bow to it. I found I had to actually bend it the other way very slightly to get it straight. And once you get into that a) it gets difficult to stop it from turning onto its side, and b) unless you have a former with a gentle curve it's tough to get a perfect result.
I got close enough (and I'm very fussy), but not 100% perfect
Re: how to straighten steel 3/8 fuel line coil [Re: Gavin] #212697
02/05/09 10:26 AM
02/05/09 10:26 AM
fresno
hyefatman Offline
hyefatman  Offline
fresno
steel fuel line- could not do it - so i cleaned up my old one--- no matter what i did it just didnt look right --- had bumps and humps and looked line crap used a tube bender no help ---
Re: how to straighten steel 3/8 fuel line coil #212698
02/05/09 11:54 AM
02/05/09 11:54 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I've run aluminum line on my street car for over 20 years. Just upgraded to 1/2" aluminum. It should be supported every 20" with proper sleeve fittings on the ends. I just read about a tubing straighten tool recently but can't remember where. I usualy over bend it when coming off the roll, go in small increments and you can get it pretty straight.
Doug
