Re: how to straighten steel 3/8 fuel line coil
[Re: mike_vango]
#212686
02/03/09 10:03 AM
02/03/09 10:03 AM
Posts: 149 Cleveland Ohio
Discoquik
Cleveland Ohio
Roll it out flat against the floor. It can be very straight after doing so. I use a 2x6 board to keep it from having any "bumps" from any cracks in the concrete. Basically roll it out like a carpet with light pressure forcing down on the roll while someone holds the other end. Very easy!
[Re: Discoquik]
#212687
02/03/09 10:07 AM
02/03/09 10:07 AM
Posts: 1,167 ERIE PA home of the RENCH MOB
mike_vango
Roll it out flat against the floor. It can be very straight after doing so. I use a 2x6 board to keep it from having any "bumps" from any cracks in the comcrete. Basically roll it out like a carpet with light pressure forcing down on the roll. Very easy!
roll it out like a carpet! thats my specialty. i'm just so afraid of kinking it.
[Re: pushbutton]
#212688
02/03/09 10:21 AM
02/03/09 10:21 AM
Challenger 1
Cincinnati, Ohio
I have seen rolls of soft copper straighted by stretching. Unroll,clamp to tree or something unmoveable and pull with a come a long or vechicle. Will work on soft copper,don't know about steel.
That's gonna change the diameter of the tubing, very bad idea and advise.
Roll it out on the floor and you will be fine. I have bought and installed 100s of rolls of copper tubing in my time, as I'm in the propane business.
[Re: Challenger 1]
#212689
02/03/09 12:26 PM
02/03/09 12:26 PM
roll out on the floor and if possible use a corner to keep it straight. Do NOT move bend or stretch any more than you absolutely must because you will work harden the piece. I used to work in refrigeration, one day I wasplaying with a scrap ofcopper tube. Two or three bends back and forth was all it took--couldn't really bend it after. If you do so, you will then have to use heat to anneal it. if it is "tinned" this can be very tricky
[Re: Challenger 1]
#212690
02/03/09 01:04 PM
02/03/09 01:04 PM
Posts: 1,565 tennessee
pushbutton
tennessee
you don't have to pull copper hard enough to change the size. I said i didn't know about steel. You will have to use tubing benders after. I've unrolled a few rolls of soft copper in my time,never saw any come out straight enough that I would want to use on a car of mine.
[Re: pushbutton]
#212691
02/03/09 01:57 PM
02/03/09 01:57 PM
Challenger 1
Cincinnati, Ohio
The OP was asking about steel tubing, I don't know how we got onto copper.
I would never use copper anywhere on any of my cars, same with aluminum tubing. It don't belong on a street car.
[Re: Challenger 1]
#212692
02/03/09 06:58 PM
02/03/09 06:58 PM
pushbutton
tennessee
I agree i wouldn' use copper either,Iwas just telling him the stretching process might work on steel tubing,but didn't know that it would.I realized he wasn't going to use copper on his car. Sorry if I confused anybody.
[Re: pushbutton]
#212693
02/03/09 08:37 PM
02/03/09 08:37 PM
It matters not whether you're speaking of copper, steel, or what. You work it the same way. You do NOT stretch it.
[Re: Challenger 1]
#212695
02/04/09 12:34 PM
02/04/09 12:34 PM
DaytonaTurbo
Manitoba, Canada
Why do you say that? What's wrong with aluminum tubing, it's a lot easier to work with...
