Re: small block rocker upgrade ?
[Re: maxwedge1]
#2125547
08/05/16 11:12 AM
08/05/16 11:12 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I see some new lower cost options. Isn't that what got you where you are now? The price of two low cost, but ineffective, rocker sets has to be more than one set of quality rockers.
[Re: maxwedge1]
#2125613
08/05/16 12:09 PM
08/05/16 12:09 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
""some of the adjusters have backed out 3 times in less than 5000 miles"". If the rockers are still good, how about just replacing the adjusters, or just the nuts with a higher quality brand? http://mantonpushrods.com/products/adjusting-screws/
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#2125675
08/05/16 01:17 PM
08/05/16 01:17 PM
RapidRobert
If the rockers are still good, how about just replacing the adjusters with a higher quality brand? that or drill/tap in horizontally to pin em with a setscrew (or both)
[Re: elmor353]
#2126316
08/06/16 02:28 AM
08/06/16 02:28 AM
RapidRobert
I am plugging the side horizontle holes in my 273 rockers, the outer one on the adjuster side, the one Ma used to drill in past the threads to the other side & I am drilling further on into the shaft to get oil from the shaft. I'm gonna clean everything well with brake kleen and loctite em. my adjusters are fairly tight but I had to swap several rockers (luckily I had plenty of spares even after experimenting & ruining several on the valve grinder problem) to get tight ones & if they were loose just me I would be OK with screwing the setscrew(s) in further till they contacted the adjuster screws after setting the lash then loctite. OT I did drill .125" holes in the shaft to line up with the rocker holes on the adjuster side and drilled holes in the rocker on the other side (& into the shaft) on the valve side to lube the valve tip (also clocked at valve closed) & I have some birdshot that I am going to plug the OE holes that are clocked wrong. I will still have the 15 deg offset holes on the bottom with the banana grooves
