Re: 33 plymouth 2 dr. sedan
[Re: 2abodymcodes]
#2123765
08/03/16 12:14 AM
08/03/16 12:14 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Got my frame and suspension all painted. here are a few pictures showing the rear end assembly. It is out of a 1990 Ford T-Bird Super Coupe. I have some questions on this set up. 1) is this set up strong enough to put behind a 490Hp Gen III 6.4 Hemi? 2) is this setup easy to find? 3) is this setup exoensive? 4) would a 4 link be stronger and/or cheaper? 5) can you easily adjust ride height?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: 2abodymcodes]
#2124165
08/03/16 05:21 PM
08/03/16 05:21 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
VERY NICE work so far ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I read somewhere that the T bird IFS waS 4 1/4" BOLT PATTERN how wide is that IFS? do the tires fit in the opening or will you need to widen the rear fenders? I thought the track width of the IFS was around 63" total, that is like a E body, about 2-3" wider than a B body rear end. just curious how it fits... ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
