Re: Low comp. + no quench vs. high comp. + quench???
[Re: an8sec70cuda]
#2122939
08/01/16 09:55 PM
08/01/16 09:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Whats the cam installed at... back it off a couple degrees so it would have less compression(the piston would be higher in the cyl).. if your like the rest of us we tend to advance them at least 4* or more for more low end
[Re: an8sec70cuda]
#2123010
08/01/16 11:16 PM
08/01/16 11:16 PM
Posts: 5,160 Texas
dannysbee
Texas
I had a 451 low deck with kb quench dome pistons and 452 heads a 223 230 at 50 cam that had 10.6 compression. It ran on pump gas on all but the hottest days. When the weather was 90+ I would add 2-3 gallons race gas. Quench was .038
Getting old just means you were smarter than some and luckier than others.
[Re: an8sec70cuda]
#2123069
08/02/16 12:17 AM
08/02/16 12:17 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I ran 10.2.1 iron headed 451 with a 284xe juice cam for 16 years no issue with an auto and loose converter. Swapped to a manual and ping city. Colder plugs and 33 total quieted it down but lost power for sure.
Mopar to the bone!!!
[Re: 72Swinger]
#2123114
08/02/16 01:25 AM
08/02/16 01:25 AM
RapidRobert
I would use different gaskets & shoot for .035" quench (to get EFFICIENT quench). & precision measuring as in my exp listed gasket thicknesses (compressed and uncompressed) can be a mile off (10-15 tho is a mile off). But on the Q at hand I ain't optomistic on avoiding quench (gas is crap & getting worse). post what you go with & how it turns out
[Re: an8sec70cuda]
#2123228
08/02/16 09:50 AM
08/02/16 09:50 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I agree with changing to a distributor you can set up with less initial, and ramp in total to match the motor. Also, anything you can do to cool the intake charge will help, obviously. Since you plan on a better motor soon, you might as well just work with the 906 heads for now, unless you want to know just how much the closed chamber heads will change things.
[Re: an8sec70cuda]
#2123398
08/02/16 01:56 PM
08/02/16 01:56 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
Chip it can't be any worse than it is... do it ...
I did a KB quench piston motor for a friend a number of years ago, it was an identical build as another KB piston motor another friend had , the only difference was one motor had the quench number at no more than .045, the other motor was .050 plus.
The tight motor had 10.3 compression, the loose one was 9.5. The tight motor ran fine on 93 octane from the pump, the 9.5 motor would ping if the owner ran anything lower than 93, i would have expected 89 to be ok.
