Low comp. + no quench vs. high comp. + quench???
#2122658
08/01/16 02:56 PM
08/01/16 02:56 PM
Posts: 13,382 Marion, South Carolina [><]
an8sec70cuda
Have somewhat of a dilemma w/ the 440 in my dad's road runner. Basic specs...440 + .040", Ross flattops .005" down from 0 deck. 509/292 purpleshaft, 1 7/8" headers, 6 pack induction, 906 heads w/ mild porting, .040" head gasket. It pings under load in hot weather w/ pump 93 gas in it. In cool weather the thing runs GREAT. You have to lug it to get it to ping...it is a 4 speed. Obviously the hotter it gets, the worse it is.
I have a set of ready to bolt on, mildly ported, big valve set of closed chamber 915 iron heads sitting on the shelf. I'd love to throw them on this car and gain some grunt, but I know it will raise the compression a decent amount. I have not CC'd them, but they are close to factory specs...minimal clean up cut on the decks.
So will the gain in compression be offset by the gain in quench as far as it tolerating pump gas? I'd hate to put them on and find out I need to mix some race fuel in it to drive it hard. What do yall think?
Re: Low comp. + no quench vs. high comp. + quench???
[Re: an8sec70cuda]
#2122691
08/01/16 03:44 PM
08/01/16 03:44 PM
an8sec70cuda
I've pulled the timing back to 35° and that helped. The car is driveable like it is, just can't lug it in hot weather.
I want to put the closed chamber heads on to gain power, but not sure if it'll be a spark rattling nightmare if I do.
[Re: an8sec70cuda]
#2122697
08/01/16 03:57 PM
08/01/16 03:57 PM
an8sec70cuda
It's about 9.9:1 right now. Should be 10.8:1 or better w/ the closed chamber heads, but it'll have good quench.
[Re: an8sec70cuda]
#2122713
08/01/16 04:10 PM
08/01/16 04:10 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
That is a good question. Best bet is aluminum 75cc heads but probably not in the cards. Colder plugs will make a difference.
Mopar to the bone!!!
[Re: an8sec70cuda]
#2122720
08/01/16 04:21 PM
08/01/16 04:21 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'd just run some octane boost in the hot weather, maybe pull another degree or two out of it, maybe try slowing the advance down a bit.
It has no quench now, so you could lower the cr a little with a thicker gasket(and not lose any quench benefit cuz you don't have any now) which should help some.
I would not be confident that combo with 10.8cr and quench would be ping free.
[Re: an8sec70cuda]
#2122728
08/01/16 04:25 PM
08/01/16 04:25 PM
an8sec70cuda
I am not interested in working w/ the 906 heads anymore. A little less timing and/or colder plugs and it'll be fine like that. I'm wondering if the better quench of the closed chamber heads will be offset by the higher compression making it even less pump gas friendly?
Different heads aren't in the equation. This motor will be replaced by a 540" hemi whenever I get around to assembling it.
[Re: fast68plymouth]
#2122733
08/01/16 04:28 PM
08/01/16 04:28 PM
an8sec70cuda
I would not be confident that combo with 10.8cr and quench would be ping free. OK, so I'd gain power but you think I'd probably be worse off than I am now as far as pinging.
[Re: an8sec70cuda]
#2122758
08/01/16 04:59 PM
08/01/16 04:59 PM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I saw this in two real similar 360 motors. One was a 9:1 with no quench and one was a 10:1 motor with quench, both motors had X heads.
The 9:1 motor had trouble on hot days like you speak of. The 10:1 quench motor was fine and was able to run a few more degrees of timing.
The biggest difference was on the track, the quench motor performed much better. I don't recall the difference but it was almost one second and several MPH faster than the non quench motor was.
This was a long time ago but both motors were pretty close. Both guys worked at the same machine shop so there was lots of consistencies between the builds, the biggest difference being the piston choice and attention to quench.
I built a quench 340 around the same time with iron heads that was a little over 10:1 and ran fine on pump gas.
68 Barracuda Formula S 340
[Re: an8sec70cuda]
#2122784
08/01/16 05:54 PM
08/01/16 05:54 PM
Posts: 43,277 Bend,OR USA
Cab_Burge
Being a street car do you have the vacume advance hook up? If not do you know what the timing is doing at the RPM it is pinging at when lugging it? The ignition timing, spark plug heat range and manifold inlet temps. will determine when it pings, cool things down on any of those three and it probally won't ping anymore I had a 21 ft inborad/outdrive plesure boat with a 8.5 to 1 compression ratio SB Chey 356 C.I. with irn heads, it would ping a little at the lower elevations we used it at, not up higher on the same gas. I change the spark plugs from RJ12YC to J11Y and that stop the pinging I wouldn't, and don't, run more then 9.5 to 1 compression on pump gas on the street with a iron headed motor, quench or no quench
[Re: Cab_Burge]
#2122787
08/01/16 06:10 PM
08/01/16 06:10 PM
an8sec70cuda
I think I may try these heads anyway...just to see. The timing is locked out. The car has a vintage air AC system...the lines are real close to the distributor and wouldn't clear the vacuum pod on the first distributor I had in it. So I put one in that's locked out w/ no pod on it. One of those things that became temporarily permanent. Been that way ever since we put it together back in 2007 or so.
[Re: an8sec70cuda]
#2122857
08/01/16 07:47 PM
08/01/16 07:47 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Yeah, get some dynamic timing going in this thing and swap the heads.
[Re: TRENDZ]
#2122862
08/01/16 07:55 PM
08/01/16 07:55 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Chip, what's the cranking compression on the thing now? Where is you initial timing set at, and which advance springs are you running? Or, when does you mechanical timing come in?
It may be as easy as running stronger advance springs to delay the timing until the engine builds some higher rpm.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: an8sec70cuda]
#2122899
08/01/16 08:57 PM
08/01/16 08:57 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I think the white head gaskets that 440 source sells are .050 gaskets. Not sure about that but they were really nice head gaskets that I always ran on my BB. I would swap heads
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
