Re: Transmission guys help if you can
[Re: MoparTod]
#212180
02/02/09 07:42 PM
02/02/09 07:42 PM
Posts: 25,933 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The generic nature of the Lokar setup makes it fit correctly on only a few carb/trans lever combos. The transmission lever is usually too long to work properly with this setup.
You need to measure the total travel of the carb lever from idle to WOT and then find a point on the trans lever that has the same travel from full forward to full back and attach the cable there. There should be a spring to pull the trans lever full forward.
Adjusting the cable so that the trans lever is full back at WOT usually results in late light throttle upshifts.
