OHM Readings for ECU Orange and Chrome Box #2120238
07/28/16 11:03 PM
07/28/16 11:03 PM
fury4speed Offline OP
I have a orange box that I think when it gets hot it does not let the car fire / no spark , I bought a chrome box new in the sealed package , the OHM readings are close but the last pin looking straight at the plug on the top right side doe snot register on the OHM meter , the orange box does so what is up , the chrome box has a higher RPM limit could that be the cause of it not registering on the OHM meter? anybody have OHM readings from a good working ECU box?
Re: OHM Readings for ECU Orange and Chrome Box [Re: fury4speed] #2120321
07/29/16 01:21 AM
07/29/16 01:21 AM
No ohm readings to offer but I would narrow it down with your meter to if it is an ecu or pickup or coil or connector/wiring issue & if it is the box then the Chrome MP box you have is a good choice
Re: OHM Readings for ECU Orange and Chrome Box [Re: RapidRobert] #2120691
07/29/16 03:44 PM
07/29/16 03:44 PM
dogdays Offline
dogdays  Offline
If the newer box has 5 pins the fifth one is a dummy.
See picture of newer chrome box.
R.
Re: OHM Readings for ECU Orange and Chrome Box [Re: dogdays] #2121573
07/30/16 10:36 PM
07/30/16 10:36 PM
It has four pins , the OHM readings were a bit different from the orange box , I installed it (MP chrome box) and it runs fine so I will see what happens , thanks again for all your suggestions.
