1970 abody 340 valve covers?? #2121412
07/30/16 05:26 PM
07/30/16 05:26 PM
Berlin, N.J.
abodyjoe Offline OP
abodyjoe  Offline OP
Berlin, N.J.
in 70 did the 340 abody valve covers differ from the run of the mill small block ones? if so how? anyone have a good pic?
anyone repopping them? i see ones for a t/a but not sure if they are the same for a abody 340..
thanks in advance..
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: 1970 abody 340 valve covers?? [Re: abodyjoe] #2121452
07/30/16 06:48 PM
07/30/16 06:48 PM
Lancaster Pa
Transamcuda Offline
Transamcuda  Offline
Lancaster Pa
I am not aware of a difference for the A-Body 340 valve covers. all 70 340 4 bbl valve covers were the same. The T/A and AAR ones had a very slight wire loom stand position and slight height difference but that was it. And they used both on the AAR's and T/A's.
Home of the AAR Registry
www.transamcuda.com
Re: 1970 abody 340 valve covers?? [Re: abodyjoe] #2121721
07/31/16 03:48 AM
07/31/16 03:48 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
A 70 340 4 barrel calve cover is the same whether it went into an A or E body
Re: 1970 abody 340 valve covers?? [Re: abodyjoe] #2121728
07/31/16 04:20 AM
07/31/16 04:20 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
What Morty said plus......The stand location was simply a variable, not just an TA/AAR thing, I've seen both locations on both Non TA/AAR cars, as well as run of the mill 340 cars.
Re: 1970 abody 340 valve covers?? [Re: abodyjoe] #2121737
07/31/16 06:32 AM
07/31/16 06:32 AM
Berlin, N.J.
abodyjoe Offline OP
abodyjoe  Offline OP
Berlin, N.J.
Re: 1970 abody 340 valve covers?? [Re: abodyjoe] #2121764
07/31/16 10:01 AM
07/31/16 10:01 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Here's a picture of my original 1970 340 valve covers after medial blasting. These were on a Duster 340.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: 1970 abody 340 valve covers?? [Re: abodyjoe] #2121779
07/31/16 10:47 AM
07/31/16 10:47 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
These all came off of original 340 4 barrel engines. The stripped pair shows two drivers sides with the two different possible plug wire upright locations.
Re: 1970 abody 340 valve covers?? [Re: ScottSmith_Harms] #2122032
07/31/16 05:22 PM
07/31/16 05:22 PM
ohio
bbtrux Offline
bbtrux  Offline
ohio
Maybe a dumb question, but, are 70 318 covers the same? Would think they would be, but may be a reason theyre not?
Re: 1970 abody 340 valve covers?? [Re: abodyjoe] #2122049
07/31/16 05:53 PM
07/31/16 05:53 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No, plug wire stand offs and wire harness tabs are different
