Re: 400-->500cui low deck combo question
[Re: Flo]
#2119822
07/28/16 02:05 PM
07/28/16 02:05 PM
Posts: 401 Berlin, Germany
Flo
Berlin, Germany
maybe stupid question, but: do the common 512cui kits with Chevy rod journals require an external oil pickup? Greets Flo
1967 Fury III 4door HT
tiny 318, late model roller block, bored and stroked to 344
[Re: Flo]
#2119896
07/28/16 03:56 PM
07/28/16 03:56 PM
Posts: 2,077 Oklahoma City
Jwilli500
Oklahoma City
Not usually. maybe stupid question, but: do the common 512cui kits with Chevy rod journals require an external oil pickup? Greets Flo
[Re: Flo]
#2119963
07/28/16 05:32 PM
07/28/16 05:32 PM
Posts: 4,694 Wichita
GY3
Wichita
maybe stupid question, but: do the common 512cui kits with Chevy rod journals require an external oil pickup? Greets Flo Can't speak to the B but on an RB block, the 4.25 crank with Chevy journals fit with internal pickup and NO grinding.
[Re: 451Mopar]
#2120408
07/29/16 08:39 AM
07/29/16 08:39 AM
Flo
Berlin, Germany
I know that article. There was also a dyno shootout on a 383 I think in Car Craft or so. That is why I thought the Torker might be a good compromise. Greets flo
[Re: Flo]
#2120628
07/29/16 02:23 PM
07/29/16 02:23 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
maybe stupid question, but: do the common 512cui kits with Chevy rod journals require an external oil pickup? Greets Flo No, you will have to grind a small amount off of the internal oil pickup boss to clear the #1 rod with or without the external or internal oil pickup I like to use the 1970/71 6 quart stock street hemi and 440 six pak oil pan with the stock 440 6 pak 3/8 pickup on the cars like ours, 1966 B bodys I ran that set up on my old pump gas Duster and never had a problem with oiling that motor on the street or at the track except letting it get a quart low once at the track and having the oil pressure drop after letting off at the 1/4 mile tracks, that was at 127+ MPH and above I used a stock Mopar windage tray with a home made crankshaft scaper also
[Re: Cab_Burge]
#2120899
07/29/16 08:55 PM
07/29/16 08:55 PM
Flo
Berlin, Germany
I plan on using the Milodon #31580 Road Race pan. If possible with internal 1/2" pickup maybe stupid question, but: do the common 512cui kits with Chevy rod journals require an external oil pickup? Greets Flo No, you will have to grind a small amount off of the internal oil pickup boss to clear the #1 rod with or without the external or internal oil pickup I like to use the 1970/71 6 quart stock street hemi and 440 six pak oil pan with the stock 440 6 pak 3/8 pickup on the cars like ours, 1966 B bodys I ran that set up on my old pump gas Duster and never had a problem with oiling that motor on the street or at the track except letting it get a quart low once at the track and having the oil pressure drop after letting off at the 1/4 mile tracks, that was at 127+ MPH and above I used a stock Mopar windage tray with a home made crankshaft scaper also
[Re: Flo]
#2121306
07/30/16 02:25 PM
07/30/16 02:25 PM
Cab_Burge
I have had blocks modified for the 1/2 inch pickups , no more after having one crack the boss when installing the bigger 1/2 inch pickups I'm sure the correct Mildon 1/2 inch pickup for that oil pan will work, make sure and check the clearance between the bottom of the pickup and the bottom of the oil pan I don't know what Milidon recommends for the minumums, I would like to see less than 1/4 inch between them for my own use
