Re: Wow... Time for 5/8“ wheel studs?!
[Re: dizuster]
#2121409
07/30/16 05:16 PM
07/30/16 05:16 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I just had the same problem. I was putting on my new M/T 315/60 Pros and noticed all my Strange wheel studs were bent as bad as yours. I am running HoleShot wheels and foot braking at 2950 lbs. I ordered a set of ARP studs and will see how they last.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#2121480
07/30/16 07:39 PM
07/30/16 07:39 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I just had the same problem. I was putting on my new M/T 315/60 Pros and noticed all my Strange wheel studs were bent as bad as yours. I am running HoleShot wheels and foot braking at 2950 lbs. I ordered a set of ARP studs and will see how they last. May as well upgrade to 5/8 now
[Re: dizuster]
#2121568
07/30/16 10:27 PM
07/30/16 10:27 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Went to take off my wheels yesterday to mount up some new tires. Couldn't believe my eyes!
Checked all of the lugs and they were all at least 100 ft/lbs to remove, so they weren't loose! Nobody so far is addressing your problem from this angle, but normal torque values 1/2" Fine Gr 8 are 90 ft/bs. I am not sure how one can relate removal torgue to tightening torque. It seems most are assuming they are the same, I'd want something to back that up. Further, the conical dry wheel hole seat, has got to significantly distort measured torque vales when tightening. And this all leads to the premise, wheels are meant to be secured to the mounting surface by the induced friction of 5 properly tightened fasteners of the necessary capacity for job. Shear resistance is not supposed to be a concern. And 5/8" studs allow typically double the torque values, with a corresponding increase in friction from the clamping they supply. I think being distracted by the centering concerns/hole design is not solving the real problem here. On drilling out conical wheels to fit larger 5/8" studs, I would hesitate, I believe one aspect of the typical conical seat design is, it allows for a slight amount of give and tension to be applied and maintained thru use and temp, etc variations, kinda like a large circular lock washer, one of the reasons on steel wheels the metal directly behind the conical seat is not designed/intended to bottom out on the axle flange, but keep a space. With 5/8" larger studs, the metal is compressed greater, into a range a 1/2" stud could not approach, but wheel hub is the same thickness. Not sure this is ideal solution, if wheels weren't ever offered in the larger stud sizes. I'd like to see the backside hub of the OP's steel wheels.
[Re: dizuster]
#2121722
07/31/16 03:49 AM
07/31/16 03:49 AM
Posts: 9,824 MI, usa
dvw
MI, usa
Easy fix. Some 10" centerline or similar flat style wheels painted green with big studs. 5/8" studs are upstairs, pick them up at the checkout. Dad
[Re: Duner]
#2121788
07/31/16 11:02 AM
07/31/16 11:02 AM
Posts: 4,974 new jersey usa
11secdart
new jersey usa
I upgraded years ago, I broke studs on the starting line and the wheel/tire came off resulting in a bent quarter panel. The studs were only a few years old. Since I have Mark Williams axles I sent them to them and had 5/8 studs installed and they have been fine ever since, I also check the torque quite frequently. On my way to Carlisle last year I broke three studs on my H.Q.C. luckily I caught it and a fellow racer works at a 4WD shop near the route I was taking was able to fix it,but I had to leave the truck and buy a new wheel. The night before I decided to check my air pressure when I did the tire valve fell apart I got it fixed and put the wheel/tire back on in the rain, I swear I tightened up all the lugs with my impact apparently I didn`t and I should have checked again before I left.
[Re: dvw]
#2121810
07/31/16 11:26 AM
07/31/16 11:26 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Easy fix. 5/8" studs are upstairs, pick them up at the checkout. Dad Hey, my kids have a checkout counter like that, too. And one of those "You Break, I Fix" style garages in the backyard. I wish I had one when I was their age.
[image][/image]
[Re: dvw]
#2122219
07/31/16 10:32 PM
07/31/16 10:32 PM
Posts: 3,509 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Easy fix. Some 10" centerline or similar flat style wheels painted green with big studs. 5/8" studs are upstairs, pick them up at the checkout. Dad Father knows best...
[Re: dizuster]
#2122226
07/31/16 10:39 PM
07/31/16 10:39 PM
sgcuda
Lots of plastic centering rings available these days. Check out some of those dub a dub or rice burner shops. I've seen a bunch come with wheels. There must be a listing for the rings by themselves.
[image][/image]
[Re: dizuster]
#2122515
08/01/16 11:46 AM
08/01/16 11:46 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Good catch!!! Makes me glad I sent my axles in to Moser earlier this year to upgrade to 5/8" studs.
[Re: an8sec70cuda]
#2122549
08/01/16 12:47 PM
08/01/16 12:47 PM
Posts: 83 washington
Bruce
washington
I got Hub rings from this place. They are made from Alcoa 6061t6 billet aluminum. They aren't cheap. http://www.motorsport-tech.com/hub_rings.htmlI used them when I put new wheels on my 2003 Grand Marquis. I got some plastic ones from the company I got the wheels from but they were crap. I don't think the plastic would hold up anyway. On the other hand, I ordered weld racing wheels for my 1965 Coronet and Weld specifically says they are lug centric and should not be balanced using the cone most shops use. There is an adapter that uses the lug holes to center the wheel for balancing.
[Re: dizuster]
#2122563
08/01/16 01:12 PM
08/01/16 01:12 PM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
5/8" hardware in the axles is one of those things that cost little to upgrade to but make a big difference in function and safety. No brainer for me in just about everything that will go to the track.
[Re: dizuster]
#2292772
04/23/17 03:48 PM
04/23/17 03:48 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
You guys and your centering rings, properly nut installation is what centers the wheel on any application. Did old Volkswagens have centering rings ? Pontiac's with 8 lug wheels? how about semi trailers with lugs to hold the wheels on. If you don't know how to properly install and tighten lug nuts to the proper torque ,read up on it or ride the bus .
[Re: rowin4]
#2292778
04/23/17 04:12 PM
04/23/17 04:12 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
You guys and your centering rings, properly nut installation is what centers the wheel on any application. Did old Volkswagens have centering rings ? Pontiac's with 8 lug wheels? how about semi trailers with lugs to hold the wheels on. If you don't know how to properly install and tighten lug nuts to the proper torque ,read up on it or ride the bus . It all depends on how the wheel/hub is designed, hub centric or lug centric. 30 years ago, most semi trucks and trailers were lug centric, now most are hub centric. Dodge D350's were lug centric till '93, they went hub centric in '94. I'll take hub over lug centric.
[Re: dizuster]
#2292849
04/23/17 06:28 PM
04/23/17 06:28 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Why stop at 5/8"? Go to 11/16".
