Page 3 of 3 1 2 3
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2120892
07/29/16 08:42 PM
07/29/16 08:42 PM
Tacoma, Washington USA
Adam71Charger Offline OP
My Bad, right on the box it says Made In China.. I was to focused looking on the piece itself
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2297861
05/02/17 06:41 PM
05/02/17 06:41 PM
Finally got my PowerBond Race Performance Harmonic Balancer PB1112SS from summit racing. $193
https://www.summitracing.com/parts/pbb-pb1112ss
Its not nice and steel like on the advertisement, looks like it was rattle canned, no sfi sticker and guess what? No county of origin printed anywhere.
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2297878
05/02/17 07:14 PM
05/02/17 07:14 PM
dogdays Offline
dogdays  Offline
The sticker is attached to the letter. I imagine you could peel it off and stick it on the damper. Then hit with some clear paint. As for where it was made, my guess is Australia. PowerBond is a brand name for Dayco.
This from Dayco Australia's Website:
"Environmental Policy
Dayco Precision Holdings Pty Ltd, located in Wagga Wagga, NSW (“Dayco Wagga”) specialises in Manufacture of Harmonic Balancers & Engine Pulleys. Dayco Wagga recognises our responsibility as a corporate citizen to sustain and protect the environment. It is a primary and fundamental objective and will be regarded as such by all persons employed by Dayco Wagga or Dayco Wagga representatives."
About the paint, Dayco Australia's website shows all of their dampers painted black. Why the Summit catalog shows them as shiny metal colored is beyond me.
R.
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2297881
05/02/17 07:20 PM
05/02/17 07:20 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
The other day I noticed trick flow came out with a damper...unfortunately it looks just like a pro sport painted black.
https://www.summitracing.com/parts/tfs-19012
Personally I've only used stock, oe stock replacement and ati.
Rich H.
Esse Quam Videri
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2297897
05/02/17 07:54 PM
05/02/17 07:54 PM
Here's the thing. Every part I've ever bought that's made in Australia or the us or Japan, always has a marking on the box or the part that says it's made from that country. Whenever there's no marking it's been my experience and it's made in China. Even the last Australian company I bought from I returned because it was made in China. And not all Chinese products are bad but when someone doesn't want you to know that their part is made in China they will leave the box or the piece blank. That is shady to me.
There are many products that are made in China that I have no problem buying but a harmonic balancer or damper is not one of them
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2297904
05/02/17 08:04 PM
05/02/17 08:04 PM
I just spoke with dayco, and they assured me it's made in Australia.
The tech guys were gone for the day so I couldn't ask them what the little plastic part and the O-ring are for. Does anyone know? My little plastic piece arrived broken but if I don't need it then I don't really care I just would like to know what they are for
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2298034
05/03/17 12:43 AM
05/03/17 12:43 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Looks exactly like the damper I got from Jeg's that is made by Pioneer.
Nautilus Racing-
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: parksr5] #2298060
05/03/17 01:12 AM
05/03/17 01:12 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted By parksr5
For what it's worth, I've had the 440 source high strength steel damper on my 470 for around three years and have not had any issues. Mainly for street use but, I've had it to the track a few times. I've shifted mine at or above 6000 a number of times and it used to go through the traps a little above 6000 but, most of the time it does not see that RPM.
Same here. Mine has been on my 505 for over a year but seen 3,500 hard street miles and lots of dragstrip passes. Rev limiter set at 6,400 rpm and usually shift close to that.
'63 Dodge 330
11.19 @ 121 mph
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2298209
05/03/17 11:57 AM
05/03/17 11:57 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
How do they ship overseas or out of country without country of origin labeling?
Page 3 of 3 1 2 3
