Lean Burn Engines Etc. #211839
02/02/09 01:00 PM
02/02/09 01:00 PM
Virginia
V
VolareOhOh Offline OP
V
Virginia
What year did the Chrysler begin putting in the Electronic Ignitions, Lean Burn engines, cat. converters, etc?
Re: Lean Burn Engines Etc. [Re: VolareOhOh] #211840
02/02/09 01:12 PM
02/02/09 01:12 PM
Shoreline, Washington
72roadrunnergtx Offline
72’ was the first year for electronic ignition, offered as an option and standard on most California bound vehicles. Lean Burn first appeared in 76’.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Lean Burn Engines Etc. [Re: 72roadrunnergtx] #211841
02/02/09 07:36 PM
02/02/09 07:36 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
1971 was the first year for electronic ignition.
Re: Lean Burn Engines Etc. [Re: formula_s] #211842
02/02/09 11:00 PM
02/02/09 11:00 PM
This document would indicate electronic ignition was first used mid-year 71’ on the 340 with manual trans A, B, & E bodies. Was not offered to the entire model line until 72’ with option code N23. I stand corrected.
Re: Lean Burn Engines Etc. [Re: formula_s] #211843
02/02/09 11:06 PM
02/02/09 11:06 PM
N
NITROUSN Offline
NITROUSN  Offline
N
It was??? On what engine?????????
