400-->500cui low deck combo question
#2117936
07/26/16 09:27 AM
07/26/16 09:27 AM
Posts: 401 Berlin, Germany
Flo
Berlin, Germany
Out to the Pros: I am currently in the planning phase for a new B-based motor for my 67 Charger. The car is an original 383 4speed (will at one point get a TKO 600) and 99% street driven. However, this is Germany, so it will be street driven HARD. It also needs to be able to sit in traffic for an hour without overheating or fouling the plugs. -Will have pretty tall gears 3.23 or 2.94. When I can afford the TKO in the next step, it might get 3.55s but not shorter by any means. -It might see a 1/8mile or even an autcross just for fun and to see how it runs. I do NOT plan to compete at anything as it does not fit any class anyhow. If it runs 13s, it runs 13s, it just should be FUN to drive and not break itself :-) -the block is a 400cui block. -will get a 440 source 500cui kit -will get a hydraulic roller conversion -headers 1 7/8 or 2" TTI , whatever fits the combo best -cam either a Mike Jones or Hughes, whatever either of them recommends for my RPM limit. -I use a MSD rev limiter in all my (classic) cars and the chip will be 6500rpm, I want to shift at around 6000 to 6200rpm -for registration (historic vehicle inspection) and style reasons a variation of the 440Source heads and a carb are a must. Now the actual QUESTION: Which head adn intake should I use? I am debating with a CNC version of the regular Stealth head vs. the CNC version of the Super Stealth with 440 port window. The Super Stealth is pretty much a copy of the Edelbrock Victor vs. the regular Stealth an Performer RPM. Hughes has a pretty nice CNC program for Victors and 440 port size, which works on the Super Stealth too: http://www.hughesengines.com/TechArticl ... php#4656S3 this would end up with Port Volume: INT 313cc EXH 84cc The regular Stealth has 255cc runner volume after the full CNC treament Considering the Victor ports are longer, port volume is difficult to compare! Unfortunately noone gives me the actual cross sectional area. To get a good idea: The Super Stealth would be 320cfm @ 0.500", the regular Stealth a littel below 300cfm@ 0.500" Now for my RPM-limit, which head would you use? Will the extra expense for the Victor / Superstealth (offset rockers....) + hood clearance issues be worth it going to the Super Stealth below 6200rpm? Or should I just use the regular CNC-Stealth and be happy about tire-shredding torque? Reminder: We are NOT talking race-car here, but what would feel better on the butt-dyno? Greets Flo
1967 Fury III 4door HT
tiny 318, late model roller block, bored and stroked to 344
Re: 400-->500cui low deck combo question
[Re: Flo]
#2117945
07/26/16 09:52 AM
07/26/16 09:52 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Flo, Do the 512 kit. Smaller rod journals, lighter rotating assembly, less issues with clearance in the block.
The CNC Stealths will do everything you need without rocker hassles, shift at 5800. I run stock stamped rockers on mine, with a small hydraulic flat tappet...two years, no parts breakage, lots of miles, lots of smiles.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: Flo]
#2117956
07/26/16 10:17 AM
07/26/16 10:17 AM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
I would suggest looking at Molnar's crank and rods. I bought a 499" crank and rods and they were spot on according to the builder Jan Cen racing engines (Mike Janis). I used JE flat tops with them. The money is close and it's a great product.
molnartechnologies.com
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Flo]
#2118014
07/26/16 12:00 PM
07/26/16 12:00 PM
Flo
Berlin, Germany
According to Hughes their CNC program for the Edelborck Victor works on the Super Stealth without changes. I know they look different from the outside, but it seems the runners and chamber are the same. Greets Flo
[Re: Flo]
#2118016
07/26/16 12:02 PM
07/26/16 12:02 PM
Flo
Berlin, Germany
For the 500 vs. 512: the bob weight on the 500cui kit is actually lower than on the 512. 500 kit 4.150" stroke/6.760" rod 512 kit 4.250" stroke/6.535" rod
I am not set on the 500 cui version, but thought the nicer geometry of the longer rod would be worth it over the 512.
[Re: Flo]
#2118027
07/26/16 12:27 PM
07/26/16 12:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
This is just my opinion but your running a low RPM engine... so the smaller runners would keep port velocity up... with the gear you plan on and big runners the engine would be slow to react... and I assume your compression will be on the low side so you can run pump fuel
[Re: Flo]
#2118059
07/26/16 01:18 PM
07/26/16 01:18 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
According to Hughes their CNC program for the Edelborck Victor works on the Super Stealth without changes. I know they look different from the outside, but it seems the runners and chamber are the same. Greets Flo So, I talked to Dave Hughes. The Edelbrock RPM program is used on the standard Stealth head and the Edelbrock Victor programs do not work on the Super Stealth. I didn't see how they could as the Victor is a raised port profile, the Super Stealth is a standard height design and the two have entirely different combustion chambers. I mean, I do have the two different heads here in the shop at this moment and they are nothing alike. I would say that between your two choices, I too would use the regular Stealth CNC program and not the Super Stealth. In our tests here you can get as much flow from the Stealth as you can from the Super Stealth.
[Re: Flo]
#2118065
07/26/16 01:25 PM
07/26/16 01:25 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'm going to give an entirely different take on it...... With the intended use of the motor....... sustained higher rpm operation.....I would want to do something with lower piston speed. Either a 451 or 470, and just run the TF heads on it.
[Re: Flo]
#2118360
07/26/16 07:02 PM
07/26/16 07:02 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I have a 500" 400 using the 4.15" crank (kit from 440 source.) The reason I went with this is to turn 7,000+ RPM.
If you plan to keep the RPM down, then the 4.25" (512" Stroker kit) would likely be better for a street car.
The ported stealth heads will work with the lower RPM level.
My 440 stroked with a 4.25" crank (only 0.030" over so a 505") has mild ported stealth heads, and a small Hydraulic roller cam, but I limited my RPM to 6,000 max. Using ISKY 8005A valve springs. I haven't tried to rev the engine over 6,000, but I think it could do more, just not taking the chance?
I have a 5-speed OD trans and 3.54:1 gear, so 50mph is about 1,500 RPM, and 100 mph about 3,000 RPM in OD.
Not sure on the intake? Do you want the air filter under the stock hood, or using a hood scoop?
[Re: LaRoy Engines]
#2118856
07/27/16 08:12 AM
07/27/16 08:12 AM
Flo
Berlin, Germany
Hi, I am glad someone doublechecked this information regarding the Super stealth! This is citation from an email from Hughes from July 8th: ...Also, please not that the “Super Stealth” cylinder head is a clone of the Edelbrock Victor head, do not confuse it with the regular “Stealth” head... Now if the Super Stealth is NOT a raised port design this would at least mean no hood clearance problems ;-) Hughes does list a CNC program for the Super Stealth. I wonder if they really have one as the tech line said it is the one for the Victors and reaches the same cfm. However with all that ??? I am going to stick with the regular CNC Stealth I think. Thanks for all the information flo
[Re: Flo]
#2118859
07/27/16 08:16 AM
07/27/16 08:16 AM
Flo
Berlin, Germany
I would like to keep everything under the stock hood. Hood scoops are not liked by inspectors and policemen around here ;-)
Is the Edelbrock Torker a reasonable manifold for 512cui 4 speed car?
Greets flo
[Re: rebel]
#2118872
07/27/16 09:13 AM
07/27/16 09:13 AM
Flo
Berlin, Germany
An Edlebrock B engined 6 pak would also be a reasonable manifold for a 512 cui 4 speed car.
one carb is enough to tune :-) Greets Flo
[Re: Flo]
#2119103
07/27/16 03:08 PM
07/27/16 03:08 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
On your deal I would buy and use the Eddy Performer RPM, it is way better from 2000 to 5000 RPM than the Torker at WOT on a engine dyno, much better on the street below 2500 RPM I love low decks with both 4.25 and 4.300 stroke cranks with both 6.700 and 6.800 long BB Chevy type H beam steel rods, way to much torque the longer rod will make the piston pin be in the oil ringland but I haven't seen any down side to that so far
[Re: Flo]
#2119185
07/27/16 05:06 PM
07/27/16 05:06 PM
451Mopar
Aurora, Colorado
Greets flo If you have it already, it should be OK. The Edelbrock Performer RPM dual plane intake and Mopar M1 single plane are also good intakes. I'm not sure on the height differences, but I think you will need a dropped base lower air filter base for clearance? At least the low deck "B" block will help the hood clearance issue compared to using a RB block.
[Re: Flo]
#2119626
07/28/16 06:30 AM
07/28/16 06:30 AM
Flo
Berlin, Germany
The Torker is shorter than the Performer RPM. That is the main reason I am interested in it.
[Re: Flo]
#2119822
07/28/16 02:05 PM
07/28/16 02:05 PM
Flo
Berlin, Germany
maybe stupid question, but: do the common 512cui kits with Chevy rod journals require an external oil pickup? Greets Flo
[Re: Flo]
#2119896
07/28/16 03:56 PM
07/28/16 03:56 PM
Posts: 2,077 Oklahoma City
Jwilli500
Oklahoma City
Not usually. maybe stupid question, but: do the common 512cui kits with Chevy rod journals require an external oil pickup? Greets Flo
[Re: Flo]
#2119963
07/28/16 05:32 PM
07/28/16 05:32 PM
Posts: 4,694 Wichita
GY3
Wichita
maybe stupid question, but: do the common 512cui kits with Chevy rod journals require an external oil pickup? Greets Flo Can't speak to the B but on an RB block, the 4.25 crank with Chevy journals fit with internal pickup and NO grinding.
[Re: 451Mopar]
#2120408
07/29/16 08:39 AM
07/29/16 08:39 AM
Flo
Berlin, Germany
I know that article. There was also a dyno shootout on a 383 I think in Car Craft or so. That is why I thought the Torker might be a good compromise. Greets flo
[Re: Flo]
#2120628
07/29/16 02:23 PM
07/29/16 02:23 PM
Cab_Burge
maybe stupid question, but: do the common 512cui kits with Chevy rod journals require an external oil pickup? Greets Flo No, you will have to grind a small amount off of the internal oil pickup boss to clear the #1 rod with or without the external or internal oil pickup I like to use the 1970/71 6 quart stock street hemi and 440 six pak oil pan with the stock 440 6 pak 3/8 pickup on the cars like ours, 1966 B bodys I ran that set up on my old pump gas Duster and never had a problem with oiling that motor on the street or at the track except letting it get a quart low once at the track and having the oil pressure drop after letting off at the 1/4 mile tracks, that was at 127+ MPH and above I used a stock Mopar windage tray with a home made crankshaft scaper also
[Re: Cab_Burge]
#2120899
07/29/16 08:55 PM
07/29/16 08:55 PM
Flo
Berlin, Germany
I plan on using the Milodon #31580 Road Race pan. If possible with internal 1/2" pickup maybe stupid question, but: do the common 512cui kits with Chevy rod journals require an external oil pickup? Greets Flo No, you will have to grind a small amount off of the internal oil pickup boss to clear the #1 rod with or without the external or internal oil pickup I like to use the 1970/71 6 quart stock street hemi and 440 six pak oil pan with the stock 440 6 pak 3/8 pickup on the cars like ours, 1966 B bodys I ran that set up on my old pump gas Duster and never had a problem with oiling that motor on the street or at the track except letting it get a quart low once at the track and having the oil pressure drop after letting off at the 1/4 mile tracks, that was at 127+ MPH and above I used a stock Mopar windage tray with a home made crankshaft scaper also
[Re: Flo]
#2121306
07/30/16 02:25 PM
07/30/16 02:25 PM
Cab_Burge
I have had blocks modified for the 1/2 inch pickups , no more after having one crack the boss when installing the bigger 1/2 inch pickups I'm sure the correct Mildon 1/2 inch pickup for that oil pan will work, make sure and check the clearance between the bottom of the pickup and the bottom of the oil pan I don't know what Milidon recommends for the minumums, I would like to see less than 1/4 inch between them for my own use
