Is this compressor size good enough for painting... #211437
02/01/09 10:32 PM
02/01/09 10:32 PM
U.S.
basik Offline OP
basik  Offline OP
U.S.
I have decided that I want to epoxy paint underneath my car and I'm also going to paint the engine bay the color of the car. To do these two jobs will this compressor size be adequate?
It is one they sell at Harbor Freight for $440.00 - 29 Gallon, 4 HP, 14.5 CFM at 90 PSI.
After tax and accessories I will be into it for over $500.00 and that is all I can afford.
Re: Is this compressor size good enough for painting... [Re: basik] #211438
02/01/09 10:38 PM
02/01/09 10:38 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
yes that more then you need for painting
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Is this compressor size good enough for painting... [Re: 1969gtx] #211439
02/01/09 10:55 PM
02/01/09 10:55 PM
U.S.
basik Offline OP
basik  Offline OP
U.S.
I was hoping that it would be enough. Here is the one I'm looking at:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92504
Re: Is this compressor size good enough for painting... [Re: basik] #211440
02/02/09 12:50 AM
02/02/09 12:50 AM
CA
David Lee Offline
David Lee  Offline
CA
Make sure you pic up a good water trap while you are there. I also have a hose I use just for painting.
Ah...so many pedestrians, so little time...
Re: Is this compressor size good enough for painting... [Re: basik] #211441
02/02/09 12:54 AM
02/02/09 12:54 AM
None
71rm23 Offline
71rm23  Offline
None
I think it will be good for everything ie Painting, airtools, media blasting, and even a blasting cabinet.
Re: Is this compressor size good enough for painting... [Re: basik] #211442
02/02/09 08:17 AM
02/02/09 08:17 AM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
Look for a toilet paper filter. These work great on small compressors. Years ago I had a copper pipe about 8 feet long coiled in a 5 gal bucket filled with water. this would cool the air so the hot humid moisture could be seperated then I had it go througt the paper filter to take out more water and oils from compresser worked great for little cash. I think the paper filter was about 60.00 or so. Clean air is very important.
Re: Is this compressor size good enough for painting... [Re: basik] #211443
02/02/09 11:24 AM
02/02/09 11:24 AM
Jacksonville Florida
elitecustombody Offline
I'll do the job just fine,not sure how well it's put together,but it should be enough for your project
