Re: Lower control Arm pivot shaft installed dry?
[Re: UCUDANT]
#2112587
07/18/16 05:34 PM
07/18/16 05:34 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I dont see why it would need lube it dosen't move. All the movement is in the bushing.Thats why the nut shouldn't be tightened until its at ride height
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: UCUDANT]
#2112671
07/18/16 07:28 PM
07/18/16 07:28 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
pin to K member, no lube
pin to bushing, rubber no lube
pin to bushing, poly lube
[Re: UCUDANT]
#2113204
07/19/16 12:29 PM
07/19/16 12:29 PM
RapidRobert
the forward facing tapered shaft? I would give it a very light coat of grease which would help with rust prevention & ease future dissassembly as there is road splash in that area. it'd take you 5 seconds
