Re: plug wires, top three or four brands?
[Re: gregsdart]
#2113898
07/20/16 11:14 AM
07/20/16 11:14 AM
Posts: 13,382 Marion, South Carolina [><]
an8sec70cuda
I have MSDs on both my motors. Both sets are 10+ years old and have been great...thinking I'll be changing them soon. I'll be putting a set of Taylors on the hemi...used them before and liked them. I will only buy wires I can cut and fit myself. Can't do that w/ Firecores.
[Re: gregsdart]
#2113906
07/20/16 11:26 AM
07/20/16 11:26 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Firecores now, had msd 8.5 both good wires. Had rfi issues with the ultra 40 wires and my progressive controller. Put aluminum plate on it moved it in between my seats and nothing helped. Changed wires fixed.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: an8sec70cuda]
#2113908
07/20/16 11:28 AM
07/20/16 11:28 AM
1967dartgt
Hilltown Pa
I have MSDs on both my motors. Both sets are 10+ years old and have been great...thinking I'll be changing them soon. I'll be putting a set of Taylors on the hemi...used them before and liked them. I will only buy wires I can cut and fit myself. Can't do that w/ Firecores. Just send in the set you made and they will copy that perfectly. They do make a nice set of wires.
[Re: gregsdart]
#2113912
07/20/16 11:33 AM
07/20/16 11:33 AM
an8sec70cuda
FWIW...my dad got a set of Firecores for his 440-6 road runner. They were supposed to be custom fit for his motor and header combination...some too short, some too long. I'll stick w/ making them myself and not hassle w/ shipping old wires back-n-forth and having downtime.
[Re: TRENDZ]
#2114186
07/20/16 04:53 PM
07/20/16 04:53 PM
Posts: 2,256 IL
furious70
IL
I use Magnecore$ 10mm on anything with turbos(heat) and electronics. Been tempted to try Firecores, but it's hard to turn away from something that I know works. Have never had a failure with the Magnecores. I used magnecore when I went EFI but then for turbo I needed to route them all underneath so needed (custom) longer- went with firecore and very happy with them, came built just like I ordered them.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: gregsdart]
#2114267
07/20/16 06:48 PM
07/20/16 06:48 PM
Posts: 1,030 ohio
67mprfan
ohio
I saw Jegs plug wires , and at a 42$ price for 8.5 spiral core wires it sounds like a good deal. Also looking at other brands. I run alky and 15/1 compression, so I need something good. What say you? Don't waste your time on the jegs brand tried them and they took a crap after about 2 months
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: an8sec70cuda]
#2115278
07/22/16 01:30 AM
07/22/16 01:30 AM
Posts: 16,520 On the run…
BloFish
On the run…
FWIW...my dad got a set of Firecores for his 440-6 road runner. They were supposed to be custom fit for his motor and header combination...some too short, some too long. I'll stick w/ making them myself and not hassle w/ shipping old wires back-n-forth and having downtime. I hear yeah!
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
