plug wires, top three or four brands?
#2113297
07/19/16 02:20 PM
07/19/16 02:20 PM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I saw Jegs plug wires , and at a 42$ price for 8.5 spiral core wires it sounds like a good deal. Also looking at other brands. I run alky and 15/1 compression, so I need something good. What say you?
Re: plug wires, top three or four brands?
[Re: gregsdart]
#2113301
07/19/16 02:24 PM
07/19/16 02:24 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
We run nothing but Taylor Spiro Pros.Last set on my 12.5 440 went like 15 years.Still worked great but looked crappy.Oh yeah even on BBs and SBs with headers no melted boots.My kid did run a part sleeve on 7 because his 62 300s headerers were 2 1/8 and close.His were on 6 years when he sold the car.Rocky
Chrysler Firepower
[Re: gregsdart]
#2113317
07/19/16 02:43 PM
07/19/16 02:43 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
X2 on the Taylors. I like the angled, molded boots seems they 'click' on better than some other brands and have the finger dimples to get them on and off with. No problem with spark at all.
'71 Duster '72 Challenger '17 Ram 1500
[Re: gregsdart]
#2113319
07/19/16 02:49 PM
07/19/16 02:49 PM
Thumperdart
State of confusion
Firecore then MSD..........If they're good enuff for Top Fuel, they're good enuff for anything..........
[Re: RMCHRGR]
#2113321
07/19/16 02:51 PM
07/19/16 02:51 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
X2 on the Taylors. I like the angled, molded boots seems they 'click' on better than some other brands and have the finger dimples to get them on and off with. No problem with spark at all. x3 on the Taylors. Been running them for almost 30 years. I like the universal kit--the plug ends are molded on but you determine the length and attached the distributor end. Never a problem. I also took the white "TAYLOR" writing off them with lacquer thinner (looks much better)
[Re: RMCHRGR]
#2113322
07/19/16 02:54 PM
07/19/16 02:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have used Taylor, MSD.. Firecore would be up there also being they use them on TF engines that run mags... I havent used the Firecore YET but I was offered a set from Rich... but I havent measured the lengths I need... I went with the big Taylors(I think they were 12mm) but I didnt like the shielding on them.. it seemed loose... my last 2 sets of wires have been MSD 9.5mm(I think thats the size.. could be 10.5).. and I put wire looms on all my wires to keep them separated plus it looks neater
[Re: gregsdart]
#2113328
07/19/16 03:01 PM
07/19/16 03:01 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I use Magnecore$ 10mm on anything with turbos(heat) and electronics. Been tempted to try Firecores, but it's hard to turn away from something that I know works. Have never had a failure with the Magnecores.
[Re: gregsdart]
#2113337
07/19/16 03:14 PM
07/19/16 03:14 PM
Posts: 188 Middletown, Ohio
Joes66dart
Middletown, Ohio
We've been running moroso ultra 40 wires with the moroso sleeves on them for a while now and have never had a problem with them.
[Re: gregsdart]
#2113348
07/19/16 03:23 PM
07/19/16 03:23 PM
Triple Threat
Renton Washington
In no particular order
Firecore MSD Moroso Ultra 40 Taylor
[Re: gregsdart]
#2113392
07/19/16 04:31 PM
07/19/16 04:31 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Normally, I just use the MSD wires. I just got some Accel 9000 for the ceramic plug boots, They seem OK, but don't fit the best with my setup. Maybe if they have a custom cut to fit kit where you can specify the ceramic end angles would be nice. I haven't had good luck with the Taylor wires. Initially they work good, but the covering is pretty soft, and I have pulled the plug ends off some when changing plugs. My headers also seem to cook the taylors more than the MSD wires, but as mentioned earlier, I burnt the MSD plug boot also, so went to the ceramic ends. Too bad Jacobs went out of business, they made decent plug wires too.
[Re: gregsdart]
#2113857
07/20/16 10:24 AM
07/20/16 10:24 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I bought some summit brand ones for my GM coil packs that I am using. I went cheap because I wasn't sure what I was going to do at first. The Summit brand ones look and feel just like Taylors and are the Taylor Blue color. I have been happy with them.
68 Barracuda Formula S 340
[Re: gregsdart]
#2113873
07/20/16 10:39 AM
07/20/16 10:39 AM
MR_P_BODY
Those that are only getting two years out of a set of MSD wires, what goes wrong? Are they 8.5 mm or bigger? I've got 5 years or more on my MSD wires.. still show good... now that I bought a new coil and moved it over to almost the left fender the coil wire is fairly long... I will see how long that last..its about 18" and being its firing all the time it will be the one to go first
