Duster slant 6 to V8 wiring harness #211188
02/01/09 07:45 PM
02/01/09 07:45 PM
Sophia, NC
67valiant340 Offline OP
super street
super street
Sophia, NC
I am installing a 340 into my 1975 Duster that originally came with a slant 6. Where can I get an engine compartment wiring harness for a V8?
Re: Duster slant 6 to V8 wiring harness [Re: 67valiant340] #211189
02/01/09 07:50 PM
02/01/09 07:50 PM
PA
70Duster Offline
70Duster  Offline
PA
You don't need one. The slant 6 harness will work as is. The temperature sender wire will be a little long, but it will work fine.
Re: Duster slant 6 to V8 wiring harness [Re: 70Duster] #211190
02/01/09 08:42 PM
02/01/09 08:42 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
No need to change the haeness.
Re: Duster slant 6 to V8 wiring harness [Re: 67valiant340] #211191
02/01/09 09:15 PM
02/01/09 09:15 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
The oil pressure sender wire will be way longer than necessary, but that's about it.
Re: Duster slant 6 to V8 wiring harness [Re: 70Duster440] #211192
02/01/09 11:44 PM
02/01/09 11:44 PM
Sophia, NC
super street
super street
Sophia, NC
Thanks for the info. I'm happy to hear that I don't need one.
Re: Duster slant 6 to V8 wiring harness [Re: 67valiant340] #211193
02/01/09 11:47 PM
02/01/09 11:47 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
If you put a big block in it they will be identical! 67-69 Darts and Barracuda's use the same engine harness for the slant and big block, just check the part numbers!
JB Rhinehart, Realist
A-Body's RULE!
