Re: 4 speed experts needed
[Re: tak]
#211113
02/01/09 07:45 PM
02/01/09 07:45 PM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
First off, the fact that it's NOT making noise in 4th tells me that it's not too likely to be the front bearing. I do wonder, though, if the "right" bearings are in there. I know that there are some repop 307 or 308 bearings that are not the proper width, or the ring groove was off (pardon me, it's been awhile) but all combined, it would allow for up to an eigth of inch of fore/aft clearance where it is NOT supposed to be. Not saying this IS your problem, but it is worth checking.
Outside of that, I would look possibly at the countershaft, as your noise issue is 1-3 only, and that's the only time you're putting power through the countershaft. 4th is direct and the power is limited to running through the mainshaft.
2 Demons...no, not my kids!
[Re: tak]
#211117
02/01/09 10:59 PM
02/01/09 10:59 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Where are you in Ohio? If you live close I could look at it for you It does sound like the cluster shaft rollers or a rough spot on the inside surface of the cluster gear may be the culprit.This is assuming you replaced the cluster pin along with the rollers and end thrust bushings as well. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#211118
02/01/09 11:19 PM
02/01/09 11:19 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
In addition to the above I would also look into the rollers in the back of the input.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: tak]
#211122
02/02/09 09:17 PM
02/02/09 09:17 PM
fourgearsavoy
Rittman Ohio
Ah yes I have been to Clyde before on my way south to Atica. The cluster pin is what the rollers ride on inside the cluster shaft. Gus
[Re: fourgearsavoy]
#211123
02/02/09 09:26 PM
02/02/09 09:26 PM
Posts: 340 Ohio
tak
Ohio
My original pin had alittle wear on it so I had Brewers send me a nice one when I bought the rebuild kit. Where is Rittman ? I work all over northern Oh from Bryan to Montrose down to Maria Stein, Fort Recovery, Brookville, Deleware, but where is Rittman ? I'm sure I've been thru it.
[Re: tak]
#211126
02/03/09 11:30 PM
02/03/09 11:30 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
Just an update, pulled the tranny apart and see nothing wrong. The shaft and cluster appear to be good. Cleaned the cluster bearings and reinstalled them and the shaft has a good fit in the cluster. It must be something in the main gear shaft or what am I missing ? Come on guys help me out. If it's not a worn shaft or gears what could it be ?
Then it could be the bearings, front or rear. I assume you put all the roller bearings inside the end of the input shaft ? The last one takes a little pressure to install.
[Re: JohnRR]
#211127
02/03/09 11:42 PM
02/03/09 11:42 PM
Some stuff you wouldn't believe:
How about the shift ball? Years ago TWO of us went down, bought a couple cue balls and drilled and tapped them, put one on my 69 383 RR and the other on my buddies '70 Chev 4x. BOTH BALLS it turns out caused a weird noise audible "in cab."
DO you have all the shields, boot, nothing touching the floor? Sure?
SURE it's not a tight/ dry U joint?
Could be a noisy rear bearing--the main ball at the tail/ box junction. I've had trouble with those. Lots of thrust/ load on it.
Inspect CAREFULLY the surfaces inside the main drive gear (I think Mopar calls it the "pinion") and the outside of the snout on the mainshaft. In any gear except 4th, there's side load on those needles. Any roughness on the surfaces/ needles could be trouble.
ARE YOU SURE they are the correct needle bearings (aftermarket sub?) and that they are all there?
Been a long long time since I've been into a box
