Re: Stage 5 Hemi conversion heads?
[Re: jughed]
#2112490
07/18/16 03:04 PM
07/18/16 03:04 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
but the flip side is he will have a basterd oddball two bolt main motor that will never be worth much. JMO. Exactly. Those 440 block Hemi heads are around only because some people want the Hemi look without having to pay the Hemi price (not implying that OP is one of those people). Did you ever price out a set of those heads? They were by no means cheap and once you add in the cost of making them fit a 440 block, you need a custom piston because a 440 starts as a .070 over hemi at standard bore. It's going to be hemi money to build a 440 with those heads.
[Re: jughed]
#2112495
07/18/16 03:11 PM
07/18/16 03:11 PM
DaytonaTurbo
Manitoba, Canada
but the flip side is he will have a basterd oddball two bolt main motor that will never be worth much. JMO. Exactly. Those 440 block Hemi heads are around only because some people want the Hemi look without having to pay the Hemi price (not implying that OP is one of those people). I would be one of those guys! If the conversion heads were cheap enough to be worth it, I would have no problem with a set of those heads between my fenders. But if you can afford a set of stage V conversion heads and custom pistons, you can afford a repro hemi block.
[Re: dogdays]
#2113928
07/20/16 11:53 AM
07/20/16 11:53 AM
JohnRR
U.S.S.A.
Pistons for Hemis cost money, no matter what diameter they are. That isn't a good reason to pooh-pooh the question.
Hemi pistons are not super expensive, but to get one for a 440 that is more than likely over bored turns it into a semi custom piston at minimum , nothing is available off the shelf. One still has to buy Hemi parts, do these bargain heads come with the rocker gear?? If not that is $$$, and as mentioned a custom cam to make up for the rocker ratio.
