Trim Screw #2106548
07/08/16 10:44 PM
07/08/16 10:44 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
Installing trim rail for 70 challenger that the gasket goes in when you put up window. Inside trim screws #8 with #6 tapper head the head seems to be to small. what screw go to this trim . .
thanks
Re: Trim Screw [Re: ct440rod] #2106700
07/09/16 05:48 AM
07/09/16 05:48 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Re: Trim Screw [Re: ct440rod] #2106725
07/09/16 10:20 AM
07/09/16 10:20 AM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
thanks Mike
Re: Trim Screw [Re: ct440rod] #2108549
07/12/16 09:20 AM
07/12/16 09:20 AM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
Going thru fasteners these must be them . .
thanks
