Re: Pormance on my 408 [Re: Wedgeman] #2107928
07/11/16 03:05 PM
07/11/16 03:05 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
If I recall, this spring I had 13.5 in the middle of a 1/4 mile track....
I' llcheck again this week end
Re: Pormance on my 408 [Re: Wedgeman] #2107975
07/11/16 04:27 PM
07/11/16 04:27 PM
Let us know, I think it will run quicker and faster with AFR in the 12.4 to 13.3 at WOT, especially in the last 1/8 mile in the 1/4 mile shruggy Have you treid jetting it up yet? If not, test, test and test some more thumbs grin
Re: Pormance on my 408 [Re: Wedgeman] #2108002
07/11/16 05:03 PM
07/11/16 05:03 PM
SoCal
Brian Hafliger Offline
SoCal
Originally Posted By Wedgeman
I was hoping you jump in Brian...
The plugs are a bit dark and the wideband says rich a bit....
But I should really be faster than just a jet change ?
Dan
If you are starving it for fuel (either by jetting or fuel supply) you can lose 1-200 HP! You basically kill the engine.
I'm not saying this is your problem, but typical 750 carbs with no PV's are jetted around 78-80's...and you have 2 carbs so think about it...it's an easy test. If nothing gets worse or better, it might be fuel supply.
Make sure you check everything else out too...I still say dyno testing is the best way to start with a new combo to get you close on tune up, and also easy way to make sure engine is healthy and happy...i.e. valve train issues is one that comes to mind.
Brian
Brian Hafliger
Re: Pormance on my 408 [Re: Wedgeman] #2108136
07/11/16 08:30 PM
07/11/16 08:30 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I was thinking the converter might be in fault.........
Re: Pormance on my 408 [Re: Wedgeman] #2108144
07/11/16 08:40 PM
07/11/16 08:40 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
What's it flair to?
Re: Pormance on my 408 [Re: Wedgeman] #2108162
07/11/16 09:10 PM
07/11/16 09:10 PM
SoCal
SoCal
This is where MPH data would help tremendously but also lack of fuel or fuel supply will show low MPH too....
Brian Hafliger
Re: Pormance on my 408 [Re: Wedgeman] #2108164
07/11/16 09:11 PM
07/11/16 09:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont think its a conv issue.. its got a strong
60'... what are your rpms at the line.. if its
slipping hard up top the rpm will tell you... I
think its all a fuel issue.. either jetting or
supply
EDIT
You might want to change the needle and seats
to .120s... but normally with 2 carbs the .110s
work fine.. but something to think of
wave
Re: Pormance on my 408 [Re: Wedgeman] #2108170
07/11/16 09:28 PM
07/11/16 09:28 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I recall last year going richer without success........the reason why I got myself a wideband
That's why I'm not sure going this direction will help, but I will keep an open eye on that this week-end....
Dan
Re: Pormance on my 408 [Re: Wedgeman] #2108196
07/11/16 10:05 PM
07/11/16 10:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dan
You need the MPH... if you jet up 4 sizes and
if nothing changes or if it doesnt slow down
(MPH) then you have a supply issue... could be
a needle and seat being to small also... do you
have a fuel gauge you can see during the run...
and dont use a oil filled gauge... if its under
the hood and filled it will show a lower pressure..
thats the oil heating up and pressing back on the
gauge
wave
Re: Pormance on my 408 [Re: Wedgeman] #2108242
07/11/16 10:43 PM
07/11/16 10:43 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Needle and seat could be an issue....I don't have a fuel gauge I can read during a pass: I can keep an eye on the fuel bowl and look the level trough the side glass ! lolll
Like I sais before, I have had that problem for the past 2 years. I went pig rich with plugs pitch black with no results...This on a single carb that went on a dyno...tested rich or lean....
Re: Pormance on my 408 [Re: Wedgeman] #2108417
07/12/16 01:01 AM
07/12/16 01:01 AM
SoCal
SoCal
What can happen on tunnel ram setups is they can pull a ton of fuel at high rpm causing performance loss in excess of 100HP and even pull enough fuel to sometimes cause the engine to rpm limit!
Hard to see when your trying to drive the car, shift, and all. Might be why the plugs are black?
Brian Hafliger
