Page 1 of 3 1 2 3
Affordable harmonic damper for a 550hp 440 shifts 6500? #2106097
07/08/16 05:12 AM
07/08/16 05:12 AM
Tacoma, Washington USA
Adam71Charger Offline OP
Whats a quality made but (relatively) affordable Damper for a internally balanced 440 that makes about 550hp and shifts at 6500rpm? I was about to get summit racings $146, but it looks like the only guy on the comments that said he shifted at 6000rpm gave a negative review and said it didnt last long. Also read a member's post here about that same Damper not last very long either.
Looking to spend $200 or below if thats possible. My main goal is longevity.
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2106103
07/08/16 06:47 AM
07/08/16 06:47 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i had a 500 hp plus 496 rb.shifted at 6000 for 3 years,only 7,000 miles though, but it did get beat on pretty reg when i did drive it.stock damper luck
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2106159
07/08/16 11:22 AM
07/08/16 11:22 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'd think about the PowerBond balancer , street performance is 152 , SFI is 192 .
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: JohnRR] #2106208
07/08/16 01:03 PM
07/08/16 01:03 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
That's what I use in applications like that.
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: fast68plymouth] #2106218
07/08/16 01:17 PM
07/08/16 01:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
which one , the street or the sfi ?
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2106243
07/08/16 01:58 PM
07/08/16 01:58 PM
So. Burlington, Vt.
So. Burlington, Vt.
In this particular instance I would base that decision on whether or not I thought I needed the sfi rating( I think the ET break for an sfi damper is 10.99).
I don't feel there is any performance advantage to either, but the sfi unit is made of better material and has a means of capturing the outer ring so it can't spin off in the event of a failure of the elastomer.
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2106483
07/08/16 08:38 PM
07/08/16 08:38 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I have been running a Professional Products damper on my 451 since it was assembled 6 years ago. It was real reasonable. Spins to 6500 regularly, no issues here.
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2106489
07/08/16 08:48 PM
07/08/16 08:48 PM
Thanks for the input. Im listing out my options here that I like for $200 or under. Liking What Ive heard so far about Powerbond. Also like what Im reading about Pro Race Products.
Non SFI
$99 - 440 Source High Strength Steel Damper
$106 - Pro Race Products Pro Street #24279
$153 - PowerBond Street Performance #PB1112ST
SFI
$186 - Pro Race Products Pro Sport #34279
$193 - PowerBond Race Performance #PB1112SS
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2106505
07/08/16 09:18 PM
07/08/16 09:18 PM
So. Burlington, Vt.
So. Burlington, Vt.
Don't know if it matters to you or not......
The lower priced Pro Race and the Professional Products dampers are made in China.
The PowerBonds are made in Australia.
I still can't bring myself to using rockers or dampers made in China.
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2106513
07/08/16 09:28 PM
07/08/16 09:28 PM
wait I thought pro race was made in Oz? Thought I read that. Just looked at their site, no where does it say where anything is made, so it probably is china. Cant avoid chinese products in america but their are some decent ones.
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2106603
07/09/16 12:32 AM
07/09/16 12:32 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have been using this one for about 8 years so far and its holding up fine. Its made in Australia as it says so right on it. And I heard the ones made in Australia are good quality as this one has been for me and the one I have on my buddies car. And it is SFI approved. Ron
http://www.manciniracing.com/prosport1.html
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2106701
07/09/16 06:18 AM
07/09/16 06:18 AM
Ron That is one of the Pro Race Products balancers Im currently interested in. You were actually the reason I thought they were made in Australia, I read your post in a similar thread to this one from about 3 years ago. Im going to call them tomorrow, or monday, and see if they still make them there
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2106707
07/09/16 08:44 AM
07/09/16 08:44 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I used one from Jeg's.It's a Jeg's brand balancer. It's made by Pioneer and is SFI rated. Less than $200.Nice balancer.
Nautilus Racing-
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2106808
07/09/16 01:30 PM
07/09/16 01:30 PM
So. Burlington, Vt.
So. Burlington, Vt.
I believe the Pioneer sfi units are made by PowerBond.
Also, I didn't say all ProRace dampers were made in china, but I'm pretty sure the budget ones are.
The steel "Pro Race" version is Aussie made.
I would be curious to know if that damper that Ron put the link to is still made in Oz.
If it is, I'd be okay with using that.
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2107109
07/10/16 01:20 AM
07/10/16 01:20 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have used 2 of these balancers. The last one I bought from Mancini in 2011 and it did say right on the box made in Australia. Course that dont mean they still are as you are right in calling them and asking if its still made there. Now I only race about once or twice a year but I put alot of street miles on my car and this balancer has worked good and stayed right on the money on my 493 and my old 440 which I bought that one around 2008. Its been fine for how I use it and it is SFI approved. It fit my budget real nice and the pulleys lined up perfect. Ron
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: fast68plymouth] #2107112
07/10/16 01:25 AM
07/10/16 01:25 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I think its still made in Oz land Dwayne but I am not 100% on that. I believe he is going to call Mancini and find out to be sure. I remember Dwayne that you were one of the guys who told me the ones made in Oz land were usually good ones and I respect your advice. up Ron
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2107646
07/11/16 12:47 AM
07/11/16 12:47 AM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
For what it's worth, I've had the 440 source high strength steel damper on my 470 for around three years and have not had any issues. Mainly for street use but, I've had it to the track a few times. I've shifted mine at or above 6000 a number of times and it used to go through the traps a little above 6000 but, most of the time it does not see that RPM.
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2107698
07/11/16 02:15 AM
07/11/16 02:15 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Rolmac used to come from oz.
I want my fair share
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: SomeCarGuy] #2108565
07/12/16 10:04 AM
07/12/16 10:04 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
The rubber is critical in a damper. I stay away from small "race" or "performance" company dampers that are made in china. I have found in general, rubber that is formulated or designed by Chinese companies is terrible. A very large reputable US manufacturer (like OEM or Dorman) will be good about making sure the correct rubber technology is in place even if made in china and I have had good experience using these. Australian units tend to be good as well.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Affordable harmonic damper for a 550hp 440 shifts 6500? [Re: Adam71Charger] #2108576
07/12/16 10:46 AM
07/12/16 10:46 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
440Source fluid damper ????
Page 1 of 3 1 2 3
