Re: BIG BLOCK HELP
[Re: topside]
#2105389
07/07/16 01:17 AM
07/07/16 01:17 AM
Posts: 2,782 USA
JoesMopar
USA
Fuel pump pushrod in the way? Yep, feel in there and slide it up in towards the block and it should go right in.
Re: BIG BLOCK HELP
[Re: Magnumguy]
#2105469
07/07/16 08:25 AM
07/07/16 08:25 AM
Posts: 601 Mass
charge70
Mass
Set the dist rotor to #6,that puts the fuel pump lobe on its low point.Easier to put the pump in.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
Re: BIG BLOCK HELP
[Re: Magnumguy]
#2105508
07/07/16 10:13 AM
07/07/16 10:13 AM
Posts: 5,139 East Aurora (Buffalo) NY
RoadRunner
I've pulled the small plug that allows the push rod to come out and inserted a piece of fuel line. The fuel line holds the push rod up against the cam and will move out of the way when the arm of the pump is aligned.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
Re: BIG BLOCK HELP
[Re: Magnumguy]
#2105671
07/07/16 02:33 PM
07/07/16 02:33 PM
Posts: 43,254 Bend,OR USA
Cab_Burge
It may slide out when you remove that plug, if it does take some wheel bearing grease(or some other thick grease) and coat it and slide it back in all the way and put the plug back in. As already pointed out by having it at TDC on #6 (soemthing I didn't know) that should allow you to push the rod up far enough in that you can slide the pump arm in between the rod and the block and insert the bolts and finish reinstalling the pump Let us know how this goes
