Re: Holley EFI Issue
[Re: MR_P_BODY]
#2105639
07/07/16 01:24 PM
07/07/16 01:24 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
MrPs ECU is definitely an HP. He gave me the part number for the system he wanted and it included the HP ECU. He ordered a "kit" and there is no part number for a kit that includes a Dominator ECU. That is all alacarte when you choose that ECU. We did talk about the Dominator, but he said he didn't need the second o2 and all the extra inputs and outputs. Also if you want trans controls, or intend to run DBW, you need the Dominator
[Re: Monte_Smith]
#2105724
07/07/16 04:07 PM
07/07/16 04:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
MrPs ECU is definitely an HP. He gave me the part number for the system he wanted and it included the HP ECU. He ordered a "kit" and there is no part number for a kit that includes a Dominator ECU. That is all alacarte when you choose that ECU. We did talk about the Dominator, but he said he didn't need the second o2 and all the extra inputs and outputs. Also if you want trans controls, or intend to run DBW, you need the Dominator With the help of Trendz we got it all loaded with the V4 and is running... I pulled fuel out at idle and will play with the idle area more.. seems to be cleaner at idle right now... just gonna have to play with it now... and being a V4 now I dont need to shrink the files to send if needed
[Re: MR_P_BODY]
#2105739
07/07/16 04:26 PM
07/07/16 04:26 PM
Thumperdart
State of confusion
MrPs ECU is definitely an HP. He gave me the part number for the system he wanted and it included the HP ECU. He ordered a "kit" and there is no part number for a kit that includes a Dominator ECU. That is all alacarte when you choose that ECU. We did talk about the Dominator, but he said he didn't need the second o2 and all the extra inputs and outputs. Also if you want trans controls, or intend to run DBW, you need the Dominator With the help of Trendz we got it all loaded with the V4 and is running... I pulled fuel out at idle and will play with the idle area more.. seems to be cleaner at idle right now... just gonna have to play with it now... and being a V4 now I dont need to shrink the files to send if needed Glad ya got it figured out Mike and was gettin back at for the "send it to the dumb guy" comment on the carb post...........
[Re: Thumperdart]
#2105747
07/07/16 04:33 PM
07/07/16 04:33 PM
MR_P_BODY
MrPs ECU is definitely an HP. He gave me the part number for the system he wanted and it included the HP ECU. He ordered a "kit" and there is no part number for a kit that includes a Dominator ECU. That is all alacarte when you choose that ECU. We did talk about the Dominator, but he said he didn't need the second o2 and all the extra inputs and outputs. Also if you want trans controls, or intend to run DBW, you need the Dominator With the help of Trendz we got it all loaded with the V4 and is running... I pulled fuel out at idle and will play with the idle area more.. seems to be cleaner at idle right now... just gonna have to play with it now... and being a V4 now I dont need to shrink the files to send if needed Glad ya got it figured out Mike and was gettin back at for the "send it to the dumb guy" comment on the carb post........... LOL... its running better... it is a HP but when I sent Trendz a file he said it was funny that it came up as a dominator in the ECU type... finally got it to change names
[Re: MR_P_BODY]
#2105756
07/07/16 04:51 PM
07/07/16 04:51 PM
Thumperdart
State of confusion
WAY above my tuning skillzzz..............
[Re: Thumperdart]
#2105760
07/07/16 05:01 PM
07/07/16 05:01 PM
MR_P_BODY
WAY above my tuning skillzzz.............. Believe me... all this computer stuff is up there for me... just like on the EFI and back years ago.. I was afraid to hit the wrong button and kill everything but it isnt that bad with some help.. mainly getting the new program into it.. now I can ask for help much easier that I can send a file.... that and a phone call
[Re: Thumperdart]
#2105879
07/07/16 08:50 PM
07/07/16 08:50 PM
MR_P_BODY
I want to thank Trendz(Rick)for ALL of his help and time putting up with my lack of knowledge of this system... he is one very patient person
[Re: MR_P_BODY]
#2105967
07/07/16 11:37 PM
07/07/16 11:37 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I want to thank Trendz(Rick)for ALL of his help and time putting up with my lack of knowledge of this system... he is one very patient person I've been called a lot of things. That is not one of them!
[Re: TRENDZ]
#2105971
07/07/16 11:41 PM
07/07/16 11:41 PM
MR_P_BODY
I want to thank Trendz(Rick)for ALL of his help and time putting up with my lack of knowledge of this system... he is one very patient person I've been called a lot of things. That is not one of them! Thanks for ALL the help buddy... I'm sure you might see a file or 2
[Re: MR_P_BODY]
#2105974
07/07/16 11:45 PM
07/07/16 11:45 PM
MR_P_BODY
I'm still set up on bank to bank fuel so its a bit of a issue to lean it down... soon I will add a crank and cam pick up to get it to sequential firing... first I'm changing the heads and cam.. all its controlling right now is fuel
