Re: 383 piston with 440 crank and rods
[Re: Moparnut426]
#2104896
07/06/16 02:00 PM
07/06/16 02:00 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
You can bush the LY rods for .990" pins, but like you said, you'd likely have enough into the LYs that you could have bought some stronger aftermarket rods. Just make sure you have the cheap aftermarket rods checked for size...they'll probably need resizing.
[Re: Moparnut426]
#2104901
07/06/16 02:06 PM
07/06/16 02:06 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
Yes for sure on the checking. I was told by the local shop that its like 25-30 per rod to have them bushed. I just got off the phone with mancinni and they told me that diamond can do changes at 6 bucks per change to a point. So with using the 516907 piston, changing the bore to 4.290, and making the pin to 1.094 it would be 96 extra bucks per set of 8 so like 740 bucks for 8 pistons. Im good with that. Ill just polish the LY rods, and put my ARP bolts in them and be done with it. the LY is going to be fine for my application anyways. If I still had the tools at my disposal Id swedge some bushings in the rods myself and pin fit them myself, but Im way away from those tools anymore.
[Re: Moparnut426]
#2104906
07/06/16 02:10 PM
07/06/16 02:10 PM
an8sec70cuda
4.090" bore??? You're gonna have those LYs resized after you put the ARP bolts in them right?
[Re: Moparnut426]
#2104922
07/06/16 02:23 PM
07/06/16 02:23 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
Im haaving a hard time finding any other than diamond. Who else sells a piston like I am after? I know someone else has to make them Its not like I am the only guy building a lil engine like this...
What CH piston are you looking for ?
[Re: Moparnut426]
#2104928
07/06/16 02:30 PM
07/06/16 02:30 PM
Moparnut426
This spec with a 4.290 bore and a 1.094 stock pin.
Bore (in): 4.280
Stroke (in): 3.375
Rod Length (in): 6.768
Piston Material: Forged aluminum
Piston Style: Flat Top
Compression Distance (in): 1.516
Dish Volume (cc): -4.0
Pin: .990 x 2.930
Piston Ring Grooves: 1/16" x 1/16" x 3/16"
Quantity: Sold as a set of 8
[Re: Moparnut426]
#2105033
07/06/16 04:52 PM
07/06/16 04:52 PM
JohnRR
U.S.S.A.
Bore (in): 4.280
Stroke (in): 3.375
Pin: .990 x 2.930
Quantity: Sold as a set of 8 So what is the problem ? Call a Diamond WD, or Diamond direct, and make it happen. 2 changes to a shelf stock piston is a small up charge, they will make it in your bore size with the big pin.
[Re: JohnRR]
#2105047
07/06/16 05:11 PM
07/06/16 05:11 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
If you are indeed running a 440 crank in a low deck with a RB length rod that compression height is not going to work for you
Ross part #99894 could work if changed for 4.290 bore
[Re: Moparnut426]
#2105052
07/06/16 05:26 PM
07/06/16 05:26 PM
GTS340
Romulus, MI
1.320-1.330 range
[Re: Moparnut426]
#2105534
07/07/16 11:00 AM
07/07/16 11:00 AM
JohnRR
U.S.S.A.
Oh yeah that was the plan, now Im just going the PEP rout since ill have 300ish into the LY rods by the time I pay the machinist Good idea , buy the cheapest of cheap chinese junk rods possible .... What material are those CCJ rods made of ???
[Re: Moparnut426]
#2105545
07/07/16 11:15 AM
07/07/16 11:15 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
so buy the Diamonds. They are good people to deal with and they make a good product.
