Re: e-85 Tuning [Re: Monte_Smith] #2106127
07/08/16 09:57 AM
07/08/16 09:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By Monte_Smith
Originally Posted By Thumperdart
I get my VP-101 unleaded from a local Arco station is that junk too........... work
That's not pump gas.
And as far as knowing the percentage drop like MrP said, that still doesn't tell you WHAT they dropped, just how much of it
On the drop sheet they have to show what was dropped
but it will say 87 octane normally.. not very often
will you see 89
wave
Re: e-85 Tuning [Re: 451Mopar] #2106142
07/08/16 10:39 AM
07/08/16 10:39 AM
NE Indiana
momopar Offline
momopar  Offline
NE Indiana
Can I post a link to Y.B.? (or is that not in good taste?)
Re: e-85 Tuning [Re: momopar] #2106185
07/08/16 12:18 PM
07/08/16 12:18 PM
Renton Washington
Triple Threat Offline
Renton Washington
Yes you can post the link.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: e-85 Tuning [Re: dthemi] #2106186
07/08/16 12:20 PM
07/08/16 12:20 PM
Renton Washington
Renton Washington
Originally Posted By dthemi
Hey P body, grab a fiver of C85, and see what you pick up sometime.
I need to do this. . . I've heard some guys picked up a few numbers and some don't notice a change. I'm sure that is very combo and tune dependent.
-Dustin
Re: e-85 Tuning [Re: 451Mopar] #2106211
07/08/16 01:09 PM
07/08/16 01:09 PM
NE Indiana
momopar Offline
momopar  Offline
NE Indiana
http://www.yellowbullet.com/forum/showthread.php?t=283787www.
This chart should help out the op. I researched widebands and there was not alot of info on re-calibrating them for e85? (even on the innovate site)
After reading this a few time it made sense that these are the numbers to shoot for.
and like Mark said "stay out of the red"
(those guys can be pretty raw over there sometimes so read at your own demise eh?)
Re: e-85 Tuning [Re: MR_P_BODY] #2106256
07/08/16 02:35 PM
07/08/16 02:35 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
will you see 89
wave
My point was, that doesn't tell you what BLEND they dropped in there. Because fuel blends change seasonally. 87 octane is not the same fuel year round. Most guys I know who bracket race with E-85 check it with a hydrometer religiously, or the car runs all over the place, at least around here
Re: e-85 Tuning [Re: Monte_Smith] #2106261
07/08/16 02:37 PM
07/08/16 02:37 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
GOOD E-85 will be in the .793 area at 60*. The problem with regular E-85 is that it is pump swill and as a result is VERY inconsistent. It can be anywhere from E-55 to E-90 and everywhere in between. Unless you buy it by the drum or mix your own, you will never be guaranteed of its consistency. It's junk fuel, just like any other pump gas
Monte,
Will the Holley Terminator ECU with the added factory style E-85 fuel sensor allow the system to "automatic" adapt to the variation in ethanol content like the flex fuel vehicles do?
Re: e-85 Tuning [Re: Monte_Smith] #2106268
07/08/16 02:52 PM
07/08/16 02:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
will you see 89
wave
I tested every time I bought E-85 from only 1 place... I
used the water tester from QF... the car was always dead
on consistent.... it never varied more than .008 all day
unless there was a BIG change in the weather... I went to
E-85 for 2 main reasons... cheap price and consistency...
it had side effects also... some good(temp) and bad.. it
liked to absorb moisture and corrode things if it sat for
any length of time... that cheap water tester work well..
I even took a sample into work and checked the fuel on our
equipment just so I could verify it
EDIT
when they make E-85 the ethanol always starts at
one point.. NEVER E-100.. its E98... the filler
product is the gas to get it to lite off easier...
so if you check the ethanol content/level it will
vary very little IF its SUMMER grade E-85.... yes
you might see a point or two.. but thats why you test
it.. winter fuel as Monte stated is as low as E-55 and
that shows up in the ethanol water test
wave
Re: e-85 Tuning [Re: 451Mopar] #2106421
07/08/16 07:38 PM
07/08/16 07:38 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The problem is the tanks are seldom empty when they drop in another batch
Re: e-85 Tuning [Re: jbc426] #2106424
07/08/16 07:42 PM
07/08/16 07:42 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Monte,
No. There is no "flex fuel" programming in the ECU..........Well let me edit that. YES, it can be done in the new V-4 software, but you have to buy some other parts from outside sources
Re: e-85 Tuning [Re: Monte_Smith] #2106427
07/08/16 07:44 PM
07/08/16 07:44 PM
Mo.
racerx Offline
racerx  Offline
Mo.
iagree this is the reason that I prefer to mix my own.
Re: e-85 Tuning [Re: racerx] #2106540
07/08/16 10:17 PM
07/08/16 10:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Test it.. it tells you the ethanol content..the
rest is filler.... its not difficult... it tells
you the ethanol level.. thats ALL your concerned
with.. like I said already.. its gonna be mixed
with 87 octane ... with the test it shows what
ethanol level it is.... PERIOD..if the ethanol
show low dont buy it...the place I buy it from
was ALWAYS 85-86 percent ethanol..but I ONLY bought
in the summer.. they have a date that they call the
change over but how low will that fuel be in there..
so I waited a month at least...I tested this stuff at
work all the time.. it was my job in the fuel lab
EDIT
the only differences in the mix is the 87 octane
that they mix with(filler) is the additives they
add.. in summer its very close... winter its a bit
higher in RVP(Reid Vapor Pressure)... summer is lower
wave
Re: e-85 Tuning [Re: 451Mopar] #2108055
07/11/16 06:37 PM
07/11/16 06:37 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Update.
I added the E-98 to my junk E-70? and got it to about 77% Ethanol.
First time trial was best, Car weight #4,179 lbs, 27x10.5 MT ET Radials, stock suspension with pinion snubber. Bandimere altitude, but I don't have a weather station to know DA, maybe 7,000 ft?
R/T = 0.007
60' = 1.849
330' = 5.003
660' = 7.619
MPH = 94.16
1000' = 9.886
1/4 ET = 11.803
MPH = 118.08
Re: e-85 Tuning [Re: 451Mopar] #2108069
07/11/16 07:05 PM
07/11/16 07:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You never stated your running E-70.. the place
your buying from must not sell much.. E-70 is
old fuel(sitting in the tanks for a long time)...
do you check the fuel before you buy... I know of
one guy on here that says all he can buy is E-70
but he changed the calibration for it... doesnt it
say E-85 on the pump
wave
