Page 3 of 3 1 2 3
can a ballast resistor in a car drain the battery? [Re: copper74] #443042
09/18/10 04:14 AM
09/18/10 04:14 AM
Las Cruces, New Mexico
ronhnm11 Offline
ronhnm11  Offline
Re: can a ballast resistor in a car drain the battery? [Re: ronhnm11] #443043
09/18/10 04:16 AM
09/18/10 04:16 AM
ronhnm11 Offline
ronhnm11  Offline
Re: can a ballast resistor in a car drain the battery? [Re: ronhnm11] #443044
09/18/10 12:52 PM
09/18/10 12:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
No. There is no power to it without the key being on.
Re: what is the purpose of a ballast resistor? [Re: Dcuda69] #443045
09/19/10 04:59 PM
09/19/10 04:59 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
You will not get output from a coil when 12 volts is applied. It is only when the 12 volts is removed that the field around the coil collapses and produces the 15k-45k secondary voltages. So, the point of fire of the plugs is when the points open up.
Re: what is the purpose of a ballast resistor? [Re: Evil Spirit] #2103997
07/04/16 11:44 PM
07/04/16 11:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted By Evil Spirit
On a points dist, all the power that goes to the coil passes through the points. Running constant 12v through the points usually burns the points up faster. <img src="/ubbthreads/images/graemlins/Twocents.gif" alt="" />
CORRECT!! the purpose of the ballast resistor, or resistance wire used by GM and Ford was to limit the current going to the coil thereby prolonging the life of the points in the "RUN" position / condition. By limiting the current it not only prolonged the points but limited the heat the coil would generate and prolonging it's life as well.
There are different coils that are designed to be used with the "resistance" IE: dropped voltage/ Current,
and those that are designed to run at full voltage. the full voltage coils typically are not used on a points system
Running full Current / voltage through a set of points will shorten their life substantially. twocents
Re: what is the purpose of a ballast resistor? [Re: TJP] #2104089
07/05/16 07:58 AM
07/05/16 07:58 AM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
The Ford tractor question/replies have been moved to their own separate thread in the General forum.
https://board.moparts.org/ubbthreads/ubbt...tml#Post2103652
Earning every penny of that moderator paycheck.
DBAP
Page 3 of 3 1 2 3
