Re: cowl mounting a fuel pressure gauge 69 road runner
[Re: jcastle1]
#2103398
07/04/16 01:57 AM
07/04/16 01:57 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
You could reach through the drivers side vent box to reach inside the cowl so you wouldn't have to cut any holes and run the line to the outer end of the cowl... where they are designed to drain.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: jcastle1]
#2103644
07/04/16 03:10 PM
07/04/16 03:10 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
Most will not run a liguid filled gauge.Ive heard lots of problems with them.IIRC a few member actually drilled a hole to let the liquid out of them.Rocky
Chrysler Firepower
[Re: jcastle1]
#2103954
07/04/16 10:43 PM
07/04/16 10:43 PM
Posts: 2,869 Pattison Texas
CSK
Pattison Texas
when the gauge gets hot it builds up pressure inside & makes it read wrong.
[Re: jcastle1]
#2103968
07/04/16 11:00 PM
07/04/16 11:00 PM
Posts: 4,278 Morrow, OH
markz528
Morrow, OH
John - you need to find someone that can drill a 0.030" hole in the vent screw in the gauge. That solves the problem. Know anyone that can do that? LOL!
[Re: Monte_Smith]
#2105451
07/07/16 03:39 AM
07/07/16 03:39 AM
Posts: 4,647 aotearoa
rebel
aotearoa
Why do you think you need a fuel pressure gauge mounted permanently to your cowl. I have 4 gauges i can check whilst racing, I do my best Marty Feldman impersonation if I hear a miss or anything out of the ordinary during a run. Fuel Pressure. Oil Pressure. Water temp. Vacuum. these 4 guages are peace of mind for me when racing as before I enter the stage beam, I check the gauges, if the run is going well then I don't look, but i still check these 4 guages when in the braking zone. If they all showed what i was expecting then its the usual checks between rounds, if not, then i have some investigation to do. I don't consider these dead weight, to me they're insurance.
[Re: jcastle1]
#2106691
07/09/16 04:14 AM
07/09/16 04:14 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
People like what they like and there is nothing wrong with that. I myself have never cared for the gauges on cowl look. I am very minimalist on what I want on a car. Oil and water are fine and you need to be consistent on water temp at staging, but that's about the last guys look at them. Oil is one of those things, that maybe you need and maybe you don't. If you look down and the pressure is low mid run, the damage is likely done anyway. You could get by with a hobbs switch that killed the ignition or turned a light on. If you lose fuel pressure, the worst that will happen is the car lay over. If you have a shift light or an auto shifter, you never use or look at tach.
I am just a freak about weight, so I hate adding stuff I never use........but that's just me.........LOL!!!
Plus, with the cost of tachs, gauges etc these days, you can buy a RacePak monitor only dash and see all you want to see. Can even get a "replay" model that will replay the run, no logger required.
I actually have the UDX "Street" dash in my gas burner dually. Speedometer, odometer, tach, voltage, water, oil pressure and temp, fuel level. Plus it also has indicator lights you can wire for turn signals, high beams, low pressure and high temp warnings. It's 600 bucks and weighs 1.3 pounds
[Re: jcastle1]
#2106720
07/09/16 10:01 AM
07/09/16 10:01 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
On our 70 Road Runner,we used a small piece of sheet metal in the shape of a "L" mounted to the screw holes where the washer nozzle hoses were. Then mounted the gauge to that. Ran the line down the lip under the cowl and to the carb.
[Re: Monte_Smith]
#2259676
02/26/17 10:39 AM
02/26/17 10:39 AM
Posts: 153 Bradenton, FL
Benforsp
Bradenton, FL
Monte, I'm actually looking at doing gauges and had thought the price point was much higher. After reading this I went to look because it would make sense to me to have the digital dash for my cars purpose. I went on the Racepak sight and I'm not sure which one you are using and I didn't find any that would do what you said for the price. Could you provide a link or more detail? I don't want to hijack and can move to a new thread if need be....
