Fitech EFI #2100868
06/30/16 12:24 AM
06/30/16 12:24 AM
NY
Beep Beep Offline OP
NY
Is anyone running the new Fitech EFI? Has anyone used the timing control that is built into the EFI4 and EFI8? I am thinking of changing to EFI but I am not sure if I should purchase the EFI box with timing control, or install an MSD 6AL programmable box with the Fitech EFI.
Re: Fitech EFI [Re: Beep Beep] #2100925
06/30/16 01:34 AM
06/30/16 01:34 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
I don't think that ecu takes the place of an ignition box like an MSD, it is the ecu that controls the injectors, that's all. the difference is that FiTech house it in the throttle body to make a neat, compact unit whereas all the others are a separate external unit - with lots of wiring!
Re: Fitech EFI [Re: Beep Beep] #2100930
06/30/16 01:41 AM
06/30/16 01:41 AM
NY
NY
Regardless of which system I go with I would still have to run my MSD box. Just curious if the timing control is worth spending the extra funds. Fuel and timing controlled by the ecm, I would think is the better way.
Re: Fitech EFI [Re: Beep Beep] #2100958
06/30/16 04:47 AM
06/30/16 04:47 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
popcorn
Re: Fitech EFI [Re: Beep Beep] #2101003
06/30/16 10:23 AM
06/30/16 10:23 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I have no experience with the FITech units, however I would buy the one that does ignition control if it's an option.
Re: Fitech EFI [Re: Beep Beep] #2101023
06/30/16 11:03 AM
06/30/16 11:03 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Call me skeptical. As a firefighter I am a trained pessimist anyway. Seems to me that the weak point of the old Lean Burn system was having the electronics controlling everything on the air cleaner atop the engine. The heat and vibration combined for an unreliable system. I think I will wait and see how they do in the long run before biting. That same thing also keeps me from the Holley Sniper as well. Add to that, the lack of user repair means either having a spare or possibly getting stranded.
BTW, for those who were wondering, EFI-4 and the Sniper do offer spark control and as far as I can tell will interface with an MSD 6 if you want capacitive discharge as well.
Re: Fitech EFI [Re: Beep Beep] #2101027
06/30/16 11:16 AM
06/30/16 11:16 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I am running the Go-EFI-8 with timing control, using a locked out MP electronic dizzy, and an old MSD 6AL.
No problems so far. Although the FITech only has 3x3 tables for spark, and 3 of those are defined in boost, so useless for NA guys.
I am only able to get 9mpg on my 493 so far...need to improve that a bit still
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Fitech EFI [Re: Beep Beep] #2101038
06/30/16 11:32 AM
06/30/16 11:32 AM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
What do you mean by this, its standard on all their units, not an option. Besides, FiTech's units are the least expense efi units on the market.
Is there anywhere that explains how the timing control works and what it does ??
Re: Fitech EFI [Re: Stanton] #2101046
06/30/16 11:49 AM
06/30/16 11:49 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Not sure I understand the question...
The mag pickup in the distributor sends signal to the FITech, the FITech then sends your desired timing signal to the MSD via the "points" wire, just as if you were running an external retard box, MSD fires coil, coil goes through cap to spark plug
In the FITech, you can identify spark timing with respect to engine speed and manifold pressure. If you have a programmable box now, or an electronic box with dialed in mechanical and vacuum advance , there is no benefit.
Re: Fitech EFI [Re: Beep Beep] #2101050
06/30/16 11:57 AM
06/30/16 11:57 AM
NY
NY
Denfireguy you do make a good point. That has crossed my mind regarding the heat and vibration.
Outlawd how much power are you making?
How easy is it to program the timing control?
Re: Fitech EFI [Re: Beep Beep] #2101052
06/30/16 12:04 PM
06/30/16 12:04 PM
NY
NY
They do make a mean street efi with no timing control. I also could not find any instruction on the timing control.
I currently have an Msd billet dizzy with no vac advance, and a msd 6al box.
Mean street is $1100 and the Efi8 is $1500.
Re: Fitech EFI [Re: Beep Beep] #2101118
06/30/16 02:04 PM
06/30/16 02:04 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Well ...
That was the technology of the time - multiple components on a large circuit board with loads of soldered connections and virtually no heat sinking. There have been significant advances since then and I suspect everything is on a single chip the size of a fingernail. The whole throttle body would act as a heat sink - the airflow through it carrying the heat away from the ECU. This is probably more effective than mounting the ECU on the firewall or inner fender.
Re: Fitech EFI [Re: Beep Beep] #2101124
06/30/16 02:12 PM
06/30/16 02:12 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
I was under the impression that the EFI8 was only for blown or turbo motors but I see that it's not.
Actually, I like the idea of the dual fan control mor than the timing control !!
Re: Fitech EFI [Re: Stanton] #2101134
06/30/16 02:33 PM
06/30/16 02:33 PM
dogdays Offline
dogdays  Offline
Electronic timing control is on every new car for at least 10 years. As part of the emission control apparatus it has to be fully functional after 100K miles.
Chrysler's Lean Burn system was a last-ditch attempt by a badly underfunded company. It is a mistake to compare it with anything else.
Electronic spark control is so much more user-friendly than the centrifugal and vacuum advance in a distributor that it should be a no-brainer, especially for those who like to run their engines at the ragged edge of detonation.
R.
Re: Fitech EFI [Re: Beep Beep] #2101144
06/30/16 02:58 PM
06/30/16 02:58 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Currently ~550, more to come with N2O, and possibly boost later on.
I got the bigger unit to allow flexibility to add more power, run E85, use it on a different engine...etc.
There is a guy with a boosted SBC running in the 9's with it I think, he is currently investigating injectors to support more power.
The main limit I see, especially for NA, is the ~860cfm rating of the throttle body
Timing control is easy, just have to have an idea where you want you timing at idle, part throttle cruise, and WOT, then enter those values into the handheld unit
Re: Fitech EFI [Re: Stanton] #2101159
06/30/16 03:17 PM
06/30/16 03:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The two base units don't have timing control.
Re: Fitech EFI [Re: Beep Beep] #2101431
06/30/16 11:56 PM
06/30/16 11:56 PM
NY
NY
I am going to try the EFI8. Thanks everyone for your input.
Re: Fitech EFI [Re: Stanton] #2101845
07/01/16 01:14 PM
07/01/16 01:14 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Well ...
True but as you know, there are still ancillary components that are needed to run the chip. And even though they are all now surface mount components there still are wires and/or pins connecting things that are soldered. Crystals still control clocks and are vibration resistant but not vibration proof. I would not store my smart phone on top of an engine, just saying.
My Megasquirt ECU sits in the passenger compartment with me.
Craig
Re: Fitech EFI [Re: denfireguy] #2101930
07/01/16 03:26 PM
07/01/16 03:26 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Can you spot the computer in this pic?
They've been there for years and it is extremely rare for us to see a failure.
- Stu Harmon
Re: Fitech EFI [Re: Beep Beep] #2102354
07/02/16 03:07 AM
07/02/16 03:07 AM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
You can never convince a pessimist !!!
