Gear Drive Cam
#2097767
06/25/16 10:00 AM
06/25/16 10:00 AM
Posts: 216 united kingdom
Simonic
united kingdom
I'm looking to replace my cam chain assembly with one of the 'noisy' gear cam drives. All the ones i'm seeing listed are for a three bolt design. Does anybody do one for a single cam bolt design please? Thank You gentlemen
Keeping the Bee Buzzin'
Re: Gear Drive Cam
[Re: Simonic]
#2097888
06/25/16 01:58 PM
06/25/16 01:58 PM
Posts: 43,295 Bend,OR USA
Cab_Burge
I'm sure someone does, try Pete Jackson(SP?) dual idler gear brand A freind and fellow racer bought one for his BB Chevy back in the mid 1970s, one of the true arc snap ring ends broke off and went through his oil pump seizng the motor at the races Almost any gear drive with straight cut gears will be noisy, the dual idlers sets are twice as noisy is my opinion
Re: Gear Drive Cam
[Re: Simonic]
#2098272
06/26/16 02:04 AM
06/26/16 02:04 AM
Posts: 6,017 Salem
Grizzly
Moparts Proctologist
Salem
I think these things are awesome, but some comments from elsewhere indicate there can be problems:
1. Oiling system not originally designed for gears, designed for chain.
2. Metal particals wearing off gears causing issues.
3. General aftermarket sloppy quality control/less than ideal fit
I'd like to believe all of this is false and a gear-driven cam is in my future, but I'm avoiding it until a proven system comes up.
Milodon and Moroso are the ones I know of. As far as I know Pete Jackson is gm/Ford only.
Mo' Farts
Moderated by "tbagger".
Re: Gear Drive Cam
[Re: Simonic]
#2098285
06/26/16 02:30 AM
06/26/16 02:30 AM
Simonic
united kingdom
Thanks gents, ill keep looking a d hopefully we may get some more info
Re: Gear Drive Cam
[Re: Grizzly]
#2098545
06/26/16 03:21 PM
06/26/16 03:21 PM
Posts: 4,758 Moved to N.E. Tennessee
GomangoCuda
Milodon and Moroso are the ones I know of. As far as I know Pete Jackson is gm/Ford only. I know Pete Jackson used to make them. I have an unused 3 bolt still in the PJ box. It is 35-40 years old. I am sure the quality is better than the Chinese double idler gear drives that are available now. Do you want one of these just for the noise? If so then it will do that but don't expect the engine to run any better than it would with a good chain.
