Yet another BB stroker camshaft suggestion thread...
#2098554
06/26/16 03:28 PM
06/26/16 03:28 PM
Posts: 76 Florida
Interceptor72
Hi all,
I am looking for cam suggestions, but my criteria are a little different than usual.
I'm building a 505 stroker (4.25" stroke) that will be going into a 4000lb car, 2.88 rear diff, and probably about 2000rpm stall. 10:1 CR. One thing I need is to have decent vacuum and only a very mild lope (would prefer something very subtle.) I'm looking for something in a hydraulic roller cam.
The motor is going into a luxury GT car (a Jensen Interceptor) and I want to keep it that way...so no radical cams. Needs decent vacuum to operate the HVAC system and power brakes. I guess that 15" vacuum would be about the minimum I would want. I've had a few cars with hotter than stock cams that had about 15" of vacuum and they always sound just right (you can hear that it is not stock, but it's still very subtle) and had plenty of vacuum to operate accessories. So this will definitely be more of a low rpm torque motor with peak HP somewhere between 5000-5500.
This might never make it to a track, so I am not looking for the fastest possible 1/4 mile time, but I do not want to leave too much on the table, either. I still want to make as much power as possible, given the restraints (don't we all...)
Re: Yet another BB stroker camshaft suggestion thread...
[Re: Interceptor72]
#2098633
06/26/16 05:43 PM
06/26/16 05:43 PM
Posts: 4,672 Wichita
GY3
Wichita
[Re: GY3]
#2098687
06/26/16 06:49 PM
06/26/16 06:49 PM
Posts: 76 Florida
Interceptor72
Sorry, forgot to specify: Stealth heads. So being aluminum, I think there won't be any detonation concerns @ 10:1 CR.
[Re: Interceptor72]
#2099113
06/27/16 09:29 AM
06/27/16 09:29 AM
Posts: 9,997 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I am a believer in the same LSA for all rpm ranges, because the heads flow the same at overlap. As duration goes up or down to suit rpm range, so does overlap duration. David Vizzard has done extensive testing to confirm this. Sooooooooooooooo, just WAG on my part, but an lsa of roughly 106 with about 232 @.050 on both sides might work well. If the recommendation is for more exhaust duration, then the LSA is just wide enough to get back to the same overlap duration for best results. A call to a pro is the real answer, since you have a very special need and a few more $$ is very well spent. Dwayne Porter of Porter Racing Heads frequents this board, and is really sharp on cams. He can have one ground to fit your exact requirements.
[Re: gregsdart]
#2099121
06/27/16 09:54 AM
06/27/16 09:54 AM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
being a Jensen you probably don't have a ton of hood clearance so you may want to look at the Indy 440-2D dual plane (sits lower than a performer RPM or a Holley Street Dominator. You're probably going to have to run exhaust manifolds that fit the chassis (or possibly small tube block huggers) as well as a relatively small-ish 2 1/2" max dual exhaust. That said I wouldn't over-think it and find a nice single pattern Hydraulic Roller in the ~236 @.050 duration and around .540-.565 lift and I would run about a 110-111 spread and put the intake centerline in around 106-107. You will have absolutely wall-to-wall torque and a very strong powerband along with excellent vacuum for power brakes. The combination will definitely feel like 505" when you tap the gas and should pull at least into 5600 rpm range. That mid 230 range for a hydraulic roller is a great all-around balance for awesome street power and torque with heavy cars and street gearing. If you wanted to you could go with a similar intake duration and a much longer but also slower exhaust ramp for that "cruise-in" "Thumper" idle....but to me that would seem out of character for a Jensen, I would go with a single pattern 236-ish @ .050. It's also very similar to what I run in my 427" Stroker small block in my Cobra Replica and the 442" AMC in my Buddy Nat's 12 second Jeep CJ-7, Great idle with just a hint of chop, instantaneous throttle response and tire melting torque all over the powerband and in any gear. Greg, the only issue I have with tight lobe spreads is he's probably going to run a very restrictive exhaust, increasing overlap when you have a restricted exhaust can kill (or severely limit the effectiveness of) that "fifth cycle" scavenging effect, especially with the mild street type compression he'll be running. As for "optimum" LSA's that really depends a lot of the head flow and valve configuration, but this one wouldn't be anything close to 106 IMHO
[Re: Streetwize]
#2099152
06/27/16 11:02 AM
06/27/16 11:02 AM
GY3
Wichita
I use a Howards hydraulic roller that sounds perfect for what you are doing. It's around .544 lift and 243° duration. Go to their website. Use a Crane composite gear and a Howards fuel pump pushrod.
The best advice is to have your Source heads CNC ported by someone like Modern Cylinder Head. You'll have well over 600 hp with very minimal effort.
[Re: ahy]
#2099212
06/27/16 12:45 PM
06/27/16 12:45 PM
Posts: 76 Florida
Interceptor72
I run 243@.050 and 108 LSA in a 496. Vacuum is 12-13" with tuning which does OK with power brakes and vacuum operated HVAC. It starts to wake up around 2000 RPM. I run a 5 speed and 3.23 rear.
For your situation this would be a bit too much I think. It would work... but the idle is a bit lumpy and smelly. Not subtle.
As a guess, around 220-230 degrees and 112 LSA would fit the need... especially considering the rest of the Jensen powertrain including rear ratio was designed for a stockish big block. Thanks, it's great to get real numbers that come from experience. And your numbers seem to align with Streetwize's recommendation. It looks like you're right: Something just a little bit less that yours will probably be just right. Right now, I'm thinking mid 230's w/ a 112LSA or lower 230s on a 110.
[Re: GY3]
#2099217
06/27/16 12:52 PM
06/27/16 12:52 PM
Posts: 76 Florida
Interceptor72
I've done a little hand porting on my Stealths. The seat and throat were a little mismatched and I cleaned that up. Also, the casting at the pinch-point was very wavy/lumpy. I smoothed that out which opened up the pinch point about 0.125" with plenty of material to go. Plus I smoothed everything else out without actually reshaping it too much. Hopefully that will make a solid difference. Certainly not as good as cnc porting, but a good chunk in that direction.
[Re: Interceptor72]
#2099228
06/27/16 01:14 PM
06/27/16 01:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Since you want stock sounding, good vac.. you should look at cam for a tow truck.. something with a wide LSA for the vac.. low duration.. mid 220s... you will hear more noise from the roller lifters than anything else and with the alum heads and the compression you should be able to run pump junk easily... your gonna have to do a bit of work on the advance curve with all the low rpm.. dont get carried away with the port work.. you want the velocity... EFI would work great on that
[Re: Interceptor72]
#2099325
06/27/16 03:17 PM
06/27/16 03:17 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
How soon are you doing this project? I'm building a 505 stroker for my '73 Jensen Interceptor, but it might be a bit hotter than your looking for. It will be around 10:1 compression, Trick Flow heads TFS-6161T784-C00, and Lunati Voodoo solid roller cam 40230732LK, 243/249@0.050", .578"/.585" 110 lsa, 106 icl. Using the Harlan Sharp 1.6:1 rockers S70016KE, so lift will be a tad more. FiTech EFI FIF-30012 on a Holley street dominator intake. I plan to dyno the engine just to see how it does, but that would be with dyno headers. I plan to make custom headers for the car.
I have quite a few parts, but I am still waiting on the cam and EFI, and I haven't get the stroker kit yet as the engine is still in the car and I want to be sure it cleans up with 0.030" overbore.
[Re: 451Mopar]
#2099427
06/27/16 05:31 PM
06/27/16 05:31 PM
Posts: 76 Florida
Interceptor72
I have quite a few parts, but I am still waiting on the cam and EFI, and I haven't get the stroker kit yet as the engine is still in the car and I want to be sure it cleans up with 0.030" overbore. I already have the engine at the machine shop and the crank (just came in Friday), rods and pistons. Got a K1 crank, scat rods and Icon pistons (-26.5cc). I've got a new 750 quickfuel carb (original holley was in bad shape) and a CH4B intake (with the Chrysler part number on it ) I'm having the machine shop put the rotating assembly together and I'll do the rest. I have all the major components except the camshaft. I'm also going to 'restore' the engine bay while the engine is out. So it will still be a couple months (I'm guessing) before I am back on the road.
[Re: Interceptor72]
#2099665
06/27/16 11:32 PM
06/27/16 11:32 PM
gregsdart
"Greg, the only issue I have with tight lobe spreads is he's probably going to run a very restrictive exhaust, increasing overlap when you have a restricted exhaust can kill (or severely limit the effectiveness of) that "fifth cycle" scavenging effect, especially with the mild street type compression he'll be running. As for "optimum" LSA's that really depends a lot of the head flow and valve configuration, but this one wouldn't be anything close to 106 IMHO twocents " Running a tight lsa means the total duration would be set to give the proper duration at overlap, not the other way around. If your cam suggestion of 236 @ .050 is on a 110 lsa, that would have 16 degrees overlap at .050 lifter rise. Soooooo, my thinking would be to get 16 degrees overlap with a 106 lsa the cam would have 228 degrees duration on both sides. You would have an intake valve closing 4 degrees earlier (better torque? vacuum?) and an exhaust cycle lasting 4 more degrees to gain a touch more torque.
[Re: davenc]
#2099827
06/28/16 09:50 AM
06/28/16 09:50 AM
Streetwize
Weddington, N.C.
Greg,
That's certainly part of it....but just because you have an overlap "constant" that doesn't take into account the differences in cylinder pressures and pumping efficiencies that the 2 different cams can/will provide, both at part throttle and WOT. To my thinking the 505" motor will benefit more from a larger 236 degree intake lobe, even if it doesn't see as much scavenging benefit from the overlap cycle (since primarily the small exhaust/blowdown is likely to limit its effectiveness at the upper part of the torque/hp curve).
I've always found with street strokers (where roll-on part throttle torque is more critical than optimum top end power...ie, 90+ % of cars driven on the street...you generally want as large an intake event as you can get without hurting torque at the lowest part of the DESIRED POWERBAND (for the load and gearing the motor sees). A 228-ish event with a tighter spread will come in ~500rpm sooner but will also be done and fall off proportionally sooner as well (for a given head flow and compression), as someone said that would be a Truck/RV style curve, or what I call an Oldsmobile curve (Tractor like torque off the line but basically all-done by ~5 grand). A Jensen would weigh about the same as a typical well optioned B body, IMHO the 236 lobe will give a 10:1 500" motor just about the perfect all around balance of smoothness, predictable roll-on power and still a decent and respectable top end rev ceiling that will feel proper (and most of all) FUN in an Interceptor.
[Re: davenc]
#2099899
06/28/16 11:58 AM
06/28/16 11:58 AM
gregsdart
Greg,
Should that be 18* of overlap at .050? Yep! I knew I should have taken that nap,,,,,,,,,
[Re: Interceptor72]
#2100172
06/28/16 09:13 PM
06/28/16 09:13 PM
451Mopar
Aurora, Colorado
I have some block huggers...the cheapy SS ones on eBay. I know they aren't great and they will need some work to fit, but they have to be better then the cast iron manifolds and they are very compact. And they have 3" collectors, which I will extend for as far as I can until I am forced down to 2.5" for the rest of the exhaust. Mine is LHD...I'm here in America. I have those SS block hugger headers too. I bought them originally thinking of running them. Maybe I can test them when I dyno the engine? For not much money, they actually look pretty good. I'll see if I can dig up a video of the Coronet. I know I have one of the car at idle, but it was when I had the RPM intake not the EFI. The car has a lot of torque, I lug it around at 1,500 rpm. It has a 5-speed manual trans, and 1,500 rpm is about 50 MPH in overdrive.
[Re: Interceptor72]
#2100542
06/29/16 01:52 PM
06/29/16 01:52 PM
451Mopar
Aurora, Colorado
I have a video on youtube of the convertible at idle. https://www.youtube.com/watch?v=0ui4GCHn_7oMy Convertible has a 505 with the -17cc pistons, I think around 10.3:1 compression with stealth heads and a Comp Hydraulic Roller cam XR286HR-10 #23-712-9, 236/242 @ 0.050", 0.544"/0.541" @ 1.5:1 rocker ratio. TTI 1-7/8" headers and 2-1/2" TTI X-Pipe exhaust with the super turbo mufflers that come with the TTI system. This is when the car had the RPM intake and Holley 770 cfm ultra avenger carb. I don't know it this video was when the engine had the CAT 1.7:1 rockers or the 1.6:1 Harlan sharpe rockers that replaced the junk CAT rockers.
[Re: Interceptor72]
#2100599
06/29/16 04:30 PM
06/29/16 04:30 PM
crabman173
crabman173
Those 511 strokers SOAK up cam --too low duration at 050 and wide LSA it will sound like a milk truck Don't over think this--like the wise say 230 ish on a 110 should be very gentle enable all your vacuum needs by far and I bet it will soon toss the Jensen rear out in the street--go with that crazy wide LSA stuff and you will hate the way it sounds That car and combo is begging for some quality muffler experimenting--with a mild cam combo you can re-gain that sexy sound if you drop serious cash on well engineered ( expensive) mufflers Think Italian car here We messed with an MGA all summer one time and after about the fifth muffler it sounded like we had an Exotic and we never touched the stock engine--there is some very beautiful sounding equipment out there--Mufflers are the last thing we get and least thought put into them--yet any exotic car makes your blood pressure go up all because they spent the effort on entire exh system simply look at new Mustangs etc to see Detroit looking into this Just my two cents Folks spend 90% of engine building on that cam and 10% on the rest--my fastest race car has a cam that came out of a 5 gallon bucket behind the door of my machine shop and was used because it was free--speced out way too little per all the conventional wisdom and turns out it is the best race engine I have ever had for $$ spent ( or lack of )
[Re: Streetwize]
#2100610
06/29/16 05:10 PM
06/29/16 05:10 PM
Posts: 16,925 NC
440Jim
NC
being a Jensen you probably don't have a ton of hood clearance so you may want to look at the Indy 440-2D dual plane (sits lower than a performer RPM or a Holley Street Dominator. . . ... Hydraulic Roller in the ~236 @.050 duration and around .540-.565 lift and I would run about a 110-111 spread and put the intake centerline in around 106-107. . . ... If you wanted to you could go with a similar intake duration and a much longer but also slower exhaust ramp I agree, pretty much what I was thinking.
[Re: 440Jim]
#2100623
06/29/16 05:53 PM
06/29/16 05:53 PM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
not a roller but it does everything you are asking for ..... hughes seh3236bl3-14 installed on 110 c/l with a 114* lobe sep.. w / 1.5' s .536 in. .546 exh. -- the dur. is 232 intake. 236 exh. @.050 mine is 10-1 comp with 915's 16* initial with 36* all in by 2500 rpm... and iron hp manifolds to boot..
[Re: 451Mopar]
#2101315
06/30/16 08:50 PM
06/30/16 08:50 PM
Posts: 76 Florida
Interceptor72
I have a video on youtube of the convertible at idle. https://www.youtube.com/watch?v=0ui4GCHn_7oMy Convertible has a 505 with the -17cc pistons, I think around 10.3:1 compression with stealth heads and a Comp Hydraulic Roller cam XR286HR-10 #23-712-9, 236/242 @ 0.050", 0.544"/0.541" @ 1.5:1 rocker ratio. TTI 1-7/8" headers and 2-1/2" TTI X-Pipe exhaust with the super turbo mufflers that come with the TTI system. This is when the car had the RPM intake and Holley 770 cfm ultra avenger carb. I don't know it this video was when the engine had the CAT 1.7:1 rockers or the 1.6:1 Harlan sharpe rockers that replaced the junk CAT rockers. Thanks for posting the vid. Sounds just about right (in neutral), but I'm thinking that with an auto in Drive with a stock-ish converter @ 700rpm, it might be a little much for my situation. So I'm thinking a single pattern in the lower 230s or a 230/236 cam might be just the ticket.
[Re: Interceptor72]
#2101474
07/01/16 12:36 AM
07/01/16 12:36 AM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
I have a video on youtube of the convertible at idle. https://www.youtube.com/watch?v=0ui4GCHn_7oMy Convertible has a 505 with the -17cc pistons, I think around 10.3:1 compression with stealth heads and a Comp Hydraulic Roller cam XR286HR-10 #23-712-9, 236/242 @ 0.050", 0.544"/0.541" @ 1.5:1 rocker ratio. TTI 1-7/8" headers and 2-1/2" TTI X-Pipe exhaust with the super turbo mufflers that come with the TTI system. This is when the car had the RPM intake and Holley 770 cfm ultra avenger carb. I don't know it this video was when the engine had the CAT 1.7:1 rockers or the 1.6:1 Harlan sharpe rockers that replaced the junk CAT rockers. Thanks for posting the vid. Sounds just about right (in neutral), but I'm thinking that with an auto in Drive with a stock-ish converter @ 700rpm, it might be a little much for my situation. So I'm thinking a single pattern in the lower 230s or a 230/236 cam might be just the ticket. Although this seems a little small, considering your choices in the carb and intake, and the likely exhaust system, this is probably about right in my book.
[Re: Interceptor72]
#2101920
07/01/16 03:14 PM
07/01/16 03:14 PM
Posts: 76 Florida
Interceptor72
About rockers:
How do I know if I have the HD stamped rockers or the regular ones? My motor is an HP motor, but I don't know if they automatically came with the HD rockers.
Are any of the stamped rockers going to be reliable with a cam around .550 lift and beehive springs?
I bought some 1.6 PAW aluminum roller rockers on clearance, but I am starting to have second thoughts about that after reading so many horror stories about aluminum roller rockers (other than the super high dollar ones.) I am also concerned that a .550 lift cam with 1.6 rockers may put a lot more stress on the valve guides causing them to wear out too quickly. For this car, I am looking more towards long term reliability than to a few extra HP on a dyno that this motor will never see. Of course, everything is a compromise when you're looking for more power, but this motor needs to be just that...a compromise between some nice power and some docility and reliability.
