3,54 or 4.1 #2097745
06/25/16 04:26 AM
06/25/16 04:26 AM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
71 duster 416 12-1 360-1 indys ported 272@50 590 lift 108 cl 105 icl installed 904 8inch 5500 coan 2.75 first gear. the car has 3.54 gears in it I was thinking of tryin this with a 26 11.50 tire. Car has caltracs on it. Or is it a waste of time and just put the 4.10 back in it with a 28 inch tire. or leave the 3.54 28 tire and spray it with 125n2o.
Re: 3,54 or 4.1 [Re: 71Pan] #2097820
06/25/16 12:10 PM
06/25/16 12:10 PM
Central NC
gch Offline
gch  Offline
Central NC
Have you run it as is?
Re: 3,54 or 4.1 [Re: 71Pan] #2097823
06/25/16 12:12 PM
06/25/16 12:12 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Always run what you have first.
Boffin Emeritus
Re: 3,54 or 4.1 [Re: 71Pan] #2097852
06/25/16 12:50 PM
06/25/16 12:50 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
Ditto
Re: 3,54 or 4.1 [Re: 71Pan] #2097895
06/25/16 02:12 PM
06/25/16 02:12 PM
I would try what I had in it first thumbs twocents See what RPM it crosses the finsh line with the NOS and without and then decide work scope I'm assuming you have both gears sets ready to go that is work I have tested a bunch of different gear ratios in Mopar cars over the years, both BB and SB, all N/A though, most of them didn't gain or loose a bunch in the 1/4 mile, that was going from 3:55 to 4:89 in a SB 4 speed car with a pump gas 366 C.I. mild motor, I did try 3:73, 3:91, 4:10 and finally 4:30 in my old pump gas Duster 518 C.I. low deck six pak stroker motor. That stupid dang car didn't change much at all with all those gear ratio swaps confused It did spend more time in high gear with the steeper 3:91, 4:10 and 4:30 gears but not much ET or MPH gain confused
With the low gear set in it will go into high gear sooner than it would with the stock low gear work
I did that swap in my old NHRA stocker, removed the 4:89 rear gears and put in the 2:77 low gear set and 4:56 in the rear, that helped the 60 ft and reaction times up
IHTHs
Re: 3,54 or 4.1 [Re: 71Pan] #2098021
06/25/16 05:53 PM
06/25/16 05:53 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
About 3 years ago I broke my 5.14 gears and threw in a set of 3.50's and I slowed down from a best of 6.34 @ 108 to a 6.39 @ 109 crossing the finish line in second gear. I was running 1/8 mile. I am running 4.56 now. It is a 394 ci small block.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: 3,54 or 4.1 [Re: D-50] #2098176
06/25/16 11:09 PM
06/25/16 11:09 PM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
great thanx guys 3.54 first
Re: 3,54 or 4.1 [Re: 71Pan] #2098226
06/26/16 12:41 AM
06/26/16 12:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
How often do you plan on spraying it.. granted your only
talking a 125 shot.. but your are playing in 2 worlds..
if you spray it the rpms will be up... try what you have
then decide on a gear.. you can do it with math but with
out the spray
wave
