Re: mopar 8 3/4 reinforced housing gasket
[Re: racerx]
#2097273
06/24/16 11:37 AM
06/24/16 11:37 AM
Posts: 22,731 Bitopia
jcc
Bitopia
x2 and what would be the reasoning for it? add toe out?
[Re: littlejohn44]
#2097381
06/24/16 02:42 PM
06/24/16 02:42 PM
Thumperdart
State of confusion
Never heard of it and never an issues w/the thick paper gasket and just a swipe of hi-temp black..............
[Re: Thumperdart]
#2097386
06/24/16 02:51 PM
06/24/16 02:51 PM
Posts: 1,237 North Central, Indiana
Roughbird72
Never heard of it and never an issues w/the thick paper gasket and just a swipe of hi-temp black.............. same here
72 Plymouth Roadrunner 11.08@123.25
[Re: littlejohn44]
#2097396
06/24/16 03:04 PM
06/24/16 03:04 PM
Posts: 20,212 Park Forest, IL
slantzilla
Park Forest, IL
Jim Cox used to sell a reusable gasket for the 8-3/4, but it was a foamy material. I used one for awhile, but I normally just use grey silicone.
[Re: Roughbird72]
#2097508
06/24/16 05:42 PM
06/24/16 05:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I just put a bead of Mopar black silicone around the whole thing(around the studs and all).. let it set for a little bit then put the pig in place and tighten the nuts with my fingers but try to make it look even all around... then a few hours later tighten them down... it dont leak... been doing that for years and all I use is 8 3/4 and now a 9" also... on the 9" I put a bead of the same stuff and put the gasket on.. another bead and let it set then put the pig on and snugged with my finger as normal then later tighten it up... its dry as a bone on the 9" also
[Re: jcc]
#2097521
06/24/16 06:39 PM
06/24/16 06:39 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
'bout time there's something re-usable on the market. I've been thinking about having a bunch of gaskets watercut from something tearresistant and durable, but till now always resorted to using silicon liquidgasket. But the amount og time required to clean/degrease and apply the RTV and final torquing later on, could be well spend on other things. x2 and what would be the reasoning for it? add toe out? Not if you install the optional axle-shaft U-joint couplers ofcourse...
[Re: littlejohn44]
#2097547
06/24/16 07:46 PM
06/24/16 07:46 PM
Posts: 4,647 aotearoa
rebel
aotearoa
That's my thinking too. This all came up when my buddy was at the track and broke a ring gear on his 9". He had it fixed between rounds. With the 8 3/4 prone it would be nice to have a quick way to fix it. You carry a spare ring & pinion in your race box?
[Re: littlejohn44]
#2097559
06/24/16 08:14 PM
06/24/16 08:14 PM
slantzilla
Park Forest, IL
I have helped 2 of my buddies change 8-3/4 pigs at the track. Took less than an hour each time. Yes, they carried spare pigs, and both were one broken tooth out of the ring gear.
[Re: rebel]
#2097602
06/24/16 09:55 PM
06/24/16 09:55 PM
Posts: 121 ky, usa
littlejohn44
ky, usa
That's my thinking too. This all came up when my buddy was at the track and broke a ring gear on his 9". He had it fixed between rounds. With the 8 3/4 prone it would be nice to have a quick way to fix it. You carry a spare ring & pinion in your race box? Doesn't everyone with an 8 3/4? lol
[Re: littlejohn44]
#2097747
06/25/16 04:42 AM
06/25/16 04:42 AM
rebel
aotearoa
That's my thinking too. This all came up when my buddy was at the track and broke a ring gear on his 9". He had it fixed between rounds. With the 8 3/4 prone it would be nice to have a quick way to fix it. You carry a spare ring & pinion in your race box? Doesn't everyone with an 8 3/4? lol i thrashed my 8 3/4 in my 'cuda for a decade. when it finally broke a cap i did this. the Mark Williams fix hadn't been invented then. as yet i haven't had a failure since. a cap for a cap.
[Re: littlejohn44]
#2101722
07/01/16 10:42 AM
07/01/16 10:42 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
I've always just used silicone w/ no gasket on 8.75 Mopars and 9" fords.
