Hemi oil pans, how big? #2096397
06/22/16 08:30 PM
06/22/16 08:30 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
For 1/4 mile racing. What are you running?
Re: Hemi oil pans, how big? [Re: Hot 340] #2096490
06/22/16 11:29 PM
06/22/16 11:29 PM
since you ain't getting any love on this Q, for a BTT, I was thinking the stock Hemi pan is 6 qts iirc
Re: Hemi oil pans, how big? [Re: RapidRobert] #2096524
06/23/16 12:10 AM
06/23/16 12:10 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
12qrt if you can fit it....my 10qrt is border lined and I will be looking to put a kick out in it soon....Been down this road many times, and 12qrt always works. 50% of the issues we have seen with a Hemi after somthing has gone wrong was oil starvation. Most the rest seem to be dropping a valve or over revving it....
Re: Hemi oil pans, how big? [Re: Hot 340] #2096539
06/23/16 12:25 AM
06/23/16 12:25 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
12 quart here as well. Dave
Re: Hemi oil pans, how big? [Re: Hot 340] #2096585
06/23/16 01:47 AM
06/23/16 01:47 AM
Cab_Burge Online work
Cab_Burge  Online Work
Is this a drag only Hemi? If so how fast and what 60 ft. times and which oiling system are you using now?
What problems are you having to make you ask this question?
Re: Hemi oil pans, how big? [Re: Hot 340] #2096649
06/23/16 10:00 AM
06/23/16 10:00 AM
an8sec70cuda Offline
7.5 quarts here. 572" hemi running 8.90s at 150 mph at 3900 lbs. Haven't had over 7.5 quarts in this motor in 10 years and never had a problem.
I use the cheap 440source fab'd aluminum pan. Milodon single line external p/u.
http://store.440source.com/Oil-Pan-Fabricated-Aluminum-8-Quart/productinfo/200-1076/
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi oil pans, how big? [Re: an8sec70cuda] #2096727
06/23/16 12:57 PM
06/23/16 12:57 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Been using the Superstock Milodon external pan & pump for 30 years.The same one in the MOPAR bible since it was written up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hemi oil pans, how big? [Re: Cab_Burge] #2096774
06/23/16 02:24 PM
06/23/16 02:24 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Come on Cab , you can't make a recommendation on such a VAGUE question ??? wink
Re: Hemi oil pans, how big? [Re: RapidRobert] #2096855
06/23/16 04:58 PM
06/23/16 04:58 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
thank ya. thumbs
Re: Hemi oil pans, how big? [Re: Dragula] #2096858
06/23/16 05:00 PM
06/23/16 05:00 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
I was checking out the Milodon road race pan... Stock chassis in my junk. You hear anything good about them Randy? Milodon 31581 is the part.
Re: Hemi oil pans, how big? [Re: Cab_Burge] #2096861
06/23/16 05:04 PM
06/23/16 05:04 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Everything is new and on the stand so i cant answer any of those questions. Well, maybe one, its gonna be street/strip. laugh2 just trying to spend money once. Mild ft cam, 4.150 stroke, pump gas deal. Stock internal pickup. Dont really want an extrenal oil line because its gonna be cramped enough.
Re: Hemi oil pans, how big? [Re: an8sec70cuda] #2096866
06/23/16 05:10 PM
06/23/16 05:10 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
punkrocka Thats movin! You running a scaper?
Re: Hemi oil pans, how big? [Re: Hot 340] #2096877
06/23/16 05:32 PM
06/23/16 05:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I try to make the pan(I build my own) as big as I
can.. but I ALWAYS run the oil height short to keep
the oil away from the crank... my current SB I built
a 10qt pan and run 7 qts in the pan plus the filter..
I also like to run a remote filter for ease of changing
the filter and the added volume... but thats just me...
and scrapers and a good windage tray help
EDIT
When running any big pan you need trap doors and walls
to keep the oil at the pick up
wave
Re: Hemi oil pans, how big? [Re: Hot 340] #2096896
06/23/16 06:26 PM
06/23/16 06:26 PM
No scraper, just a Milodon windage tray. up
CHIP
Re: Hemi oil pans, how big? [Re: Hot 340] #2097113
06/24/16 01:15 AM
06/24/16 01:15 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Just remember oil is your friend. You can live with to much oil but will suffer a horrible death with to little. Dave
Re: Hemi oil pans, how big? [Re: Hot 340] #2097147
06/24/16 01:58 AM
06/24/16 01:58 AM
[/quote] Everything is new and on the stand so i cant answer any of those questions. Well, maybe one, its gonna be street/strip. laugh2 just trying to spend money once. Mild ft cam, 4.150 stroke, pump gas deal. Stock internal pickup. Dont really want an extrenal oil line because its gonna be cramped enough. [/quote]If your putting the motor in a 1966 to 1970 B or a 1970 to 1971 E body I would look at the stock 1970/71 426 Street Hemi/440 6 pak oil pan with the stock 1/2 pickup scope thumbs I used one of those with the stock 440 6 pak 3/8 inch oil pick up in my old pump gas Duster with a 518 C.I. low deck stroker with a solid roller cam that I oiled the rockers full time to help cool the valve spring, I drove it on street meekly and ran it at the strip shifting it above 7000 RPM in each gear hammer That car weighed 3450 lbs with me in it and ran a best of 9.993 at 134.8 MPH through the complete 3 inch exhaust system and air cleaner on boogie I never had a problem with that oil pan and stock 3/8 440 6 pak oil pickup as long as I didn't let it get down on oil to the add oil line on the calibrated dip stick thumbs 6 quarts in the pan and one in the stock type oil filter, ran good, lasted a long time thumbs I use that pan and stock 440 6 pak 3/8 pickup now on all my BB B and E body street car builds work scope thumbs
