Stamp pad #2096805
06/23/16 03:05 PM
06/23/16 03:05 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
I am wanting to get a stamp pad made so I can re stamp amp my electronic voltage regulator with the proper scrip and date code and so forth, anybody know where these can be had?
Re: Stamp pad [Re: 71birdJ68] #2096834
06/23/16 04:22 PM
06/23/16 04:22 PM
kentucky
b body idiot Offline
kentucky
Try Office Depot had a pad made there before
Re: Stamp pad [Re: 71birdJ68] #2096836
06/23/16 04:23 PM
06/23/16 04:23 PM
kentucky
kentucky
Re: Stamp pad [Re: 71birdJ68] #2096851
06/23/16 04:55 PM
06/23/16 04:55 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I used this company on multiple occasions. They were very friendly and easy to deal with.
http://www.discountrubberstamps.com/stamps/traditional-rubber-stamps
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Stamp pad [Re: 71birdJ68] #2100035
06/28/16 04:31 PM
06/28/16 04:31 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
You sure you want to rubber stamp?
Looking at NOS I too first went the rubber stamp route, but the results just didn't look as crisp as the NOS units. As a result I ended up silk screening mine, and it appears to be much closer in appearance to originals.
Re: Stamp pad [Re: 71birdJ68] #2100287
06/28/16 11:47 PM
06/28/16 11:47 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Try ECS for a transfer. Way easier than trying to make a stamp.
Re: Stamp pad [Re: Morty426] #2100298
06/29/16 12:01 AM
06/29/16 12:01 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Even easier, ECS offers NOS voltage regulators with the required/specified date codes for 70-1 vehicles
Re: Stamp pad [Re: DAYCLONA] #2100349
06/29/16 01:02 AM
06/29/16 01:02 AM
Morristown Tn.
Morristown Tn.
I've got three NOS regulators, the ones with the bump and all of them let it make to much voltage for a repo battery. I put a new one from Mopar performance on and it did ok voltage wise. I guess after 40 years the just don't work as good anymore. I was going to make a bump for the new one and have a stamp made if I could find one.
Thanks all.
