Removing pinion yoke on 742 case??? #2096600
06/23/16 02:33 AM
06/23/16 02:33 AM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
So I need to remove the pinion yoke so I can remove the dust shield. I haven't done much with 3rd members besides swap them out. So my knowledge with them is minimal.
Can I remove the yoke and replace it without issue? Or is there a certain way this has to be done?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Removing pinion yoke on 742 case??? [Re: DemonDust] #2096604
06/23/16 02:58 AM
06/23/16 02:58 AM
CA
crackedback Offline
crackedback  Offline
CA
Should be easy, no crush sleeve in a 742.
Re: Removing pinion yoke on 742 case??? [Re: crackedback] #2096610
06/23/16 03:36 AM
06/23/16 03:36 AM
I think pull it with a steering wheel puller
Re: Removing pinion yoke on 742 case??? [Re: DemonDust] #2096611
06/23/16 03:44 AM
06/23/16 03:44 AM
Menomonee Falls
Menomonee Falls
I'm more concerned about putting it back on. If I torque it to the proper specs it should be good since there is no crush sleeve correct? I know with a 489 case I had I changed to the bigger u joint and it ended up crushing the sleeve more and then rear was noisy.
SDG Motorsports
Re: Removing pinion yoke on 742 case??? [Re: DemonDust] #2096695
06/23/16 12:06 PM
06/23/16 12:06 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Check the break-away torque with a ft-lbs dial-type torque wrench prior to pulling it apart. This way you can tighten up the nut to a break away torque close to what you had and everything will be really close to where you started. Bt break-away torque I mean the amount of ft-lb on the dial it takes to rotate the yoke.
Re: Removing pinion yoke on 742 case??? [Re: DemonDust] #2096812
06/23/16 03:16 PM
06/23/16 03:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yoke removal/installation won't affect the pinion bearing preload on a 742.
Re: Removing pinion yoke on 742 case??? [Re: John_Kunkel] #2096825
06/23/16 03:55 PM
06/23/16 03:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep... pull it off and torque to spec... the solid spacer
makes it nice to change minor things on the 742
wave
