Tuning...a/f readings #2096139
06/22/16 11:09 AM
06/22/16 11:09 AM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
just thought i'd throw this out in case someone has run in to a similar problem
a/f is 14 - 14.5 at idle
light cruise 14 - 14.5 at 1200 - 2000rpm but when i step it up to 2500 - 3000
the a/f ratio goes to about 12 - 12.5
thinking about leaning out the cruise circuit but seems o.k up to about 2000 rpm.
lighter step up springs?
your thoughts?
Re: Tuning...a/f readings [Re: can.al] #2096158
06/22/16 11:33 AM
06/22/16 11:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What carb
wave
Re: Tuning...a/f readings [Re: can.al] #2096189
06/22/16 12:47 PM
06/22/16 12:47 PM
Az
Crizila Offline
Crizila  Offline
Az
That's actually not bad. Did you have a vacuum gage on it to see if you were in to the PV? Were you driving it under load? You could also try a little larger hi speed air bleed if yours are adjustable.
Fastest 300
Re: Tuning...a/f readings [Re: can.al] #2096222
06/22/16 02:03 PM
06/22/16 02:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You could be seeing the opening point of the p/v or you`re on the primary jets pulling through the boosters.....either way looks good accordingly.....
Re: Tuning...a/f readings [Re: MR_P_BODY] #2096236
06/22/16 02:29 PM
06/22/16 02:29 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Originally Posted By MR_P_BODY
What carb
wave
X2
Re: Tuning...a/f readings [Re: justinp61] #2096244
06/22/16 02:46 PM
06/22/16 02:46 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
1405 edelbrock (600 cfm man. choke)
think i'll try a lighter step up spring...maybe lower vacuum at higher speed
is pulling the metering rods into the power circuit a bit early?
Re: Tuning...a/f readings [Re: can.al] #2096266
06/22/16 03:30 PM
06/22/16 03:30 PM
Az
Crizila Offline
Crizila  Offline
Az
Follow the little tuning booklet that came with that carb - in particular the graph.
Fastest 300
Re: Tuning...a/f readings [Re: can.al] #2096280
06/22/16 03:40 PM
06/22/16 03:40 PM
I like to see 14.8 to 15.8 AFR on idle and part throttle cruise at engine operating temps, not on start up twocents To lean out the main circuit at or above 2500 RPM try enlarging the bottom step on the primary rods, both sides up Leave the part throttle step the same size, if you can thumbs
Re: Tuning...a/f readings [Re: can.al] #2096287
06/22/16 03:54 PM
06/22/16 03:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
OOPS............LOL
Re: Tuning...a/f readings [Re: can.al] #2096316
06/22/16 05:00 PM
06/22/16 05:00 PM
central il.
second 70 Offline
second 70  Offline
central il.
Check your vacuum at 3000 your rods are probability still in the down position if you are only cruising. So the big part of the rod needs to increase. The off idle cruise under 2000 might still be on the idle circuit and that's the reason it's good. One rod larger should get you to 13/1 two steps should be 13.5. The cruise is the big part of the two step rod and the smaller end is for power mode.
Re: Tuning...a/f readings [Re: can.al] #2096374
06/22/16 07:05 PM
06/22/16 07:05 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
i have just ordered new metering rods.
..step up springs had no effect so i'll lean the cruise circuit next
Re: Tuning...a/f readings [Re: Cab_Burge] #2096376
06/22/16 07:09 PM
06/22/16 07:09 PM
Az
Crizila Offline
Crizila  Offline
Az
14.8 to 15.8 will boarder on a lean miss condition, especially if you have any fuel distribution issues at all ( reads most single plane manifolds). I don't use AFR readings much for setting idle mixtures. Prefer using best vacuum and idle rpm. Best way to address those one or two lean holes IMO.
Fastest 300
Re: Tuning...a/f readings [Re: can.al] #2096422
06/22/16 09:39 PM
06/22/16 09:39 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
What he said.
