SB mopar thin head gaskets available? #209571
01/31/09 05:01 PM
01/31/09 05:01 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
Who has the mopar .028 4.060 head gaskets in stock? I can't find them any where
Re: SB mopar thin head gaskets available? [Re: HotRodDave] #209572
01/31/09 07:08 PM
01/31/09 07:08 PM
Lexington South Carolina
johnnyp Offline
johnnyp  Offline
call cometic gaskets they make a .027
Re: SB mopar thin head gaskets available? [Re: johnnyp] #209573
01/31/09 07:26 PM
01/31/09 07:26 PM
Kalispell Mt.
Kalispell Mt.
way more than the $40 I am used to paying for the mopar ones.
I am throwing a pair of magnum heads and an XE268 in my 318 because I have them sitting around, thought it would be a cheap upgrade from the current .039 felpros. I can not do this swap unless I can do it super cheap and I still gota buy conversion pushrods, intake, exhaust, and valve cover gaskets.
Re: SB mopar thin head gaskets available? [Re: HotRodDave] #209574
01/31/09 07:32 PM
01/31/09 07:32 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: SB mopar thin head gaskets available? [Re: 70AARcuda] #209575
01/31/09 07:51 PM
01/31/09 07:51 PM
next best thing is MR Gasket 1121
http://store.summitracing.com/partdetail.asp?part=MRG%2D1121&autoview=sku
the only problem with that is you don't gain any compression because of the huge bore of the gasket. total waste of time and effort IMO.
Re: SB mopar thin head gaskets available? #209576
01/31/09 08:19 PM
01/31/09 08:19 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
any suggestions then ?????
Tony
Re: SB mopar thin head gaskets available? [Re: 70AARcuda] #209577
01/31/09 08:57 PM
01/31/09 08:57 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
could try your local Chrysler dealer
Re: SB mopar thin head gaskets available? [Re: 70AARcuda] #209578
02/01/09 09:28 AM
02/01/09 09:28 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
I have an extra set. P4120094
