625 cfm street demon carb swap on small block #2093263
06/17/16 12:05 AM
06/17/16 12:05 AM
pass christian, ms
69fish Offline OP
69fish  Offline OP
pass christian, ms
I have a 273 2 bbl engine from an auto trans car I am swapping out for a 318 with 360 heads and 4 barrel manifold. Will my 273 throttle linkage work with this carb? I do have a factory 4 bbl small block throttle pressure rod to swap out for the 2bbl one, but the rest of the linkage setup is 2 bbl stuff. Will the 2bbl carb stud transfer to demon carb or do I have to order theirs? Any other mods need to be made? Hope to hear from those who have made this swap. Thanks for any help.
Re: 625 cfm street demon carb swap on small block [Re: 69fish] #2093301
06/17/16 01:16 AM
06/17/16 01:16 AM
the short horizontle pin will bolt in to the hole in the throttle linkage and just need the 4bbl horizontle rod with the long slotted hole
