Re: Solid Flat Tappet VS Solid Roller [Re: MR_P_BODY] #2093184
06/16/16 09:09 PM
06/16/16 09:09 PM
Washington
madscientist Offline
Washington
George is a good guy. I always forget to mention Clay Smith when talking about cam companies that aren't comp.
His stuff should work good for you.
Re: Solid Flat Tappet VS Solid Roller [Re: MR_P_BODY] #2093284
06/17/16 12:46 AM
06/17/16 12:46 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Originally Posted By MR_P_BODY
Originally Posted By csk
I have 155 seat on my small solid ft, but i also have trend tool steel edm lifters.
I'm gonna run AMC lifters on this... I have to oil via
the PRs
wave
mine also has PR oiling.
Re: Solid Flat Tappet VS Solid Roller [Re: justinp61] #2093426
06/17/16 10:58 AM
06/17/16 10:58 AM
MR_P_BODY Offline OP
Originally Posted By justinp61
I do like that cam...its a bit large for what I wanted but
I'm sure they make some smaller... I might look at some of
their others..and set the this one on the shelf..in the end
it could be cheaper
wave
Re: Solid Flat Tappet VS Solid Roller [Re: MR_P_BODY] #2093577
06/17/16 04:42 PM
06/17/16 04:42 PM
I bought a custom version of that cam also... I'll
put the Clay Smith in my back up engine or leave it
as a roller.. depends what heads I have on it.. the
one in the Rampage will take a couple of weeks to get
here but thats the one going in the 416... I can leave
the 1.5 rockers on it and put the W-5s on the 416... had it
ground on a 110 lsa.... plus I bought their light weight lifters...
so I have enough cams to last me for a while.. both rollers
and solid FT ones... damn these solid FT cams are CHEAP
compared to rollers
wave
